Mecheng70 Posted August 13, 2016 Posted August 13, 2016 I am finding that the main screen does not correlate to the second screen for zwave open/close door window sensors. For example: The main screen will indicate that the window or door is open. Which is incorrect. However the second screen or device screen indicates the correct status: Am I missing something? Sent from my PURE XL using Tapatalk
James Peterson Posted August 15, 2016 Posted August 15, 2016 You are probably correct. most of the zwave devices I just guess about settings and structure of the node since there is not way to view them without having one. Could you send me a node dump of that device? How To: if you need it. http://www.agaveha.com/documentation/node-dump/
Mecheng70 Posted August 16, 2016 Author Posted August 16, 2016 Here you go. Updated with the correct node. <node flag="128"> <address>ZW025_1</address> <name>z_Sensor DeckDoor</name> <family>4</family> <parenttype="3">24139</parent> <type>4.32.1.0</type> <enabled>true</enabled> <deviceClass>0</deviceClass> <wattage>0</wattage> <dcPeriod>0</dcPeriod> <startDelay>0</startDelay> <endDelay>0</endDelay> <pnode>ZW025_1</pnode> <sgid>1</sgid> <devtype> <gen>4.32.1</gen> <mfg>265.8193.258</mfg> <cat>104</cat> </devtype> <ELK_ID>C13</ELK_ID> <property id="ST" value="0"formatted="Off" uom="78"/> </node> Sent from my PURE XL using Tapatalk
Mecheng70 Posted August 17, 2016 Author Posted August 17, 2016 </node> <node flag="128"> <address>ZW024_1</address> <name>z_Sensor FrontDoor</name> <family>4</family> <parenttype="3">24139</parent> <type>4.32.1.0</type> <enabled>true</enabled> <deviceClass>0</deviceClass> <wattage>0</wattage> <dcPeriod>0</dcPeriod> <startDelay>0</startDelay> <endDelay>0</endDelay> <pnode>ZW024_1</pnode> <sgid>1</sgid> <devtype> <gen>4.32.1</gen> <mfg>265.8193.258</mfg> <cat>104</cat> </devtype> <ELK_ID>C10</ELK_ID> <property id="ST" value="0"formatted="Off" uom="78"/> </node>
Mecheng70 Posted August 19, 2016 Author Posted August 19, 2016 What other node dumps would you like? I have motion sensors with temp, window door sensors (all have tamper security), water sensor. Sent from my iPhone using Tapatalk
Mecheng70 Posted August 25, 2016 Author Posted August 25, 2016 Any update? My trial times out and I'm deciding if I still want to continue with it. Sent from my PURE XL using Tapatalk
James Peterson Posted August 25, 2016 Posted August 25, 2016 Any update? My trial times out and I'm deciding if I still want to continue with it. Sent from my PURE XL using Tapatalk Sorry, been zoned out working on other things recently. I'll try to have it fixed or at least an answer by this evening.
Mecheng70 Posted August 25, 2016 Author Posted August 25, 2016 Sorry, been zoned out working on other things recently. I'll try to have it fixed or at least an answer by this evening. Thanks. Sent from my iPhone using Tapatalk
James Peterson Posted August 25, 2016 Posted August 25, 2016 Thanks. Sent from my iPhone using Tapatalk FYI - I took a quick look at it. simple fix. I'll try to pop a few other bugs this evening and get it pushed out. thanks for helping. I can't say it enough. This would be impossible without community members like yourself sending me information, node dumps and all the feedback.
Mecheng70 Posted August 25, 2016 Author Posted August 25, 2016 Do you need motion sensor (with temp) node dumps? Have two different ones (one reports temp in C and the other in F). In fact one way you could stand out is if you could have agave calculate from C to F and vice versa. Sent from my iPhone using Tapatalk
James Peterson Posted August 25, 2016 Posted August 25, 2016 Do you need motion sensor (with temp) node dumps? Have two different ones (one reports temp in C and the other in F). In fact one way you could stand out is if you could have agave calculate from C to F and vice versa. Sent from my iPhone using Tapatalk post it as a suggestion here: https://bitbucket.org/jamespet/agave/issues
James Peterson Posted August 25, 2016 Posted August 25, 2016 Do you need motion sensor (with temp) node dumps? Have two different ones (one reports temp in C and the other in F). In fact one way you could stand out is if you could have agave calculate from C to F and vice versa. Sent from my iPhone using Tapatalk I can always use more devices. Are these zwave devices?
Mecheng70 Posted August 25, 2016 Author Posted August 25, 2016 Yes they are. Quick question; Is Full Acccess (Portal) (Agave) plus add on program and variables The same as Full access (Variables)(Agave) plus add-on ISY portal???? Cost is different. $25 + $8 versus $20 + $10. Am I missing something? Sent from my iPhone using Tapatalk
James Peterson Posted August 25, 2016 Posted August 25, 2016 It would be the same thing. you are not missing anything. I have adjusted pricing to match. should take effect after a few hours.
Mecheng70 Posted August 26, 2016 Author Posted August 26, 2016 Thanks and purchased. I will post on the site this weekend. I am separating out the devices. Sent from my PURE XL using Tapatalk
