Logic debugging colours
larryllix
In the Admin Console
We now have folder colours to indicate If section logic outcome.
Would it be possible to extend the same idea to individual logic lines in order to breakdown complex logic for debugging?
eg.
HVAC.HRV.cycle - [iD 00AD][Parent 00BD][Not Enabled]
             $sHouse.temperature >= $sHouse.temp.setpoint     <---line  logic is False
         And $sHouse.temperature >= $sHouse.outTemp         <---line  logic is True
     Or (
             $sHouse.temperature <= $sHouse.temp.setpoint
         And $sHouse.temperature <= $sHouse.outTemp
     Or (
             'Gathering Room / GathRm VenStat' Mode is Heat   <--- both True
         And $sHouse.dewPoint.in <= $sHouse.dewPoint.out    <---we have a winner
     Or (
             'Gathering Room / GathRm VenStat' Mode is Cool
         And $sHouse.dewPoint.in >= $sHouse.dewPoint.out
        Set 'HVAC / HRV Fan.control' On
        Wait  30 minutes
        Set 'HVAC / HRV Fan.control' Off
        Wait  3 minutes
This feature may need to be on a switch, timer, or only on the program currently displayed, to avoid ISY/comm channel bog down.
