PLM problem?
Well I hate to post on my first day, but I'm stuck already...
I'm not able to set up my Insteon devices (29 of them) from the Administrative Control Screen.  When I click on the Start Linking button, nothing happens.   I can't enter the individual six digit address for manual set-up (I get error messages).  When I click on the PLM Info/Status button on in Diagnostics, it says Not Connected.
I changed Cat5 cables from the ISY994iZW to the PLM to confirm it wasn't a cable issue.  I also changed from a 10 ft cable to a 3 ft cable (not real convenient) to rule out any cable length issue.
The PLM lights up when plugged in.
Is there anything I might be doing wrong, or do I have a PLM or ISY994i problem?
Are you sure the Ethernet jack from the PLM is connected to the right jack?
It must be or he wouldn't be able to get to the admin console.
Best regards,
Gary Funk
Use the Help|About menu pulldown and verify if your firmware matches your UI version. They must match.
Make sure you power up the PLM and let it initialize before powering up the ISY994i.
So the PLM check can find it when the ISY994i powers up.
Best regards,
Gary Funk
I must be dyslexic today please ignore my first post!
This didn't seem to help.  I'll try it again this afternoon.
The firmware and UI match, but appears to be missing the Zwave info.  I have an ISY994iZW.
Put up a screen shot of the About box.
Best regards,
Gary Funk
Try clicking on the light bulb icon. Don't press any Link buttons on devices unless they are battery devices.
I don't know what that "Start Linking" does and never use it
This is what I get after filling in the six digit Insteon code:
OK, I figure out that I had to pay $1 to get the Zwave activated...
Attached is the screen shot image of when I click on the diagnostic for PLM.
If you have done the PLM first power thing and still can't get "PLM/Info connected" and you don't have any real devices connected or programs I would try a factory reset on your ISY.
I am not sure how to do that anymore but it probably involves holding down the buried microbutton for a long time.
EDIT: http://www.universal-devices.com/docs/production/user_guide_3.2.6.pdf   Appendix B
PLM and Zwave are not related but two different interfaces.
PLM handles Insteon and X10, Zwave is a small PCB plugged inside on a motherboard.
I did a test.
Power down my PLM and disconnect the serial cable from the ISY994i
Cycled the power to the ISY994i. The Blue RX LED is ON all the time. TX flashes occasionally.
Administrative Console opens with a warning screen Your System is in Safe Mode.
Are you getting the warning message and Blue RX LED On?
I am trying to figure out if the PLM is not answering at all or is not responding after the original
PLM discovery.
Edited by Brian H
I did a test.
PLM discovery.
I did a factory reset with no change, and also powered down both PLM and ISY, restarting the PLM first.  No change.
The only light that is on is the blue power light.  No Blue RX light at a normal state; it only lights up when powering up.  I don't get the warning message about Safe Mode.
I'm thinking I either have a defective PLM or defective port on the ISY...
Screen shot image is attached.
OK I just looked at the firmware you have installed.
It is the version that will work with or with out a PLM and not generate an error on startup if no PLM is found. So a Z-Wave only system will not generate a PLM error with no PLM but still can also use a PLM for Insteon.
So my thoughts are the PLM maybe bad or there is a serial port issue in the ISY994i.
My bets are hedged to the PLM as they have a very poor reputation.
Opening a trouble ticket with UDI will probably get you a more definite answer.
Edited by Brian H
You may want to open a support ticket.
The UDI Team is top of the line when it comes to support.
They maybe able to do added tests to determine if it is the PLM or ISY994i.
Maybe reference this thread.
http://www.universal-devices.com/contact-support/
UDI tech support was quick and friendly. Suggested that the PLM is likely bad so I'm getting it replaced. I'll update this thread when I get it in.
  • 3 weeks later...
Well, I got a new PLM and all seems to be good now!
I'll be getting everything dialed in over the next few days and weeks.  I'll likely be having more questions when I run into roadblocks but all good for now.
I appreciate the help!
When you replace the PLM be sure to follow the replacement instructions found here (scroll down to PLM replacement):
Do not do a DELETE MODEM
  https://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:File_Menu
  • 1 month later...
The instructions guide you to replace the plm thats connected to ISY.
My smartenit eziso8 PLM just went bad and I ordered a replacement, I cant find any instructions for that, so what do I do differently?
For example it states:
  1.  If you are replacing a defective PLM, choose a backup from right before the PLM died. This is a very important step
I dont think thats important for smartenit Plm replacement.
I'm not familiar with the smartenit devices. Hopefully someone can answer your question.
it has nothing to do with smartenit, the point is that the plm is not the ISY plm, its a device plm.
