Can't control Aeotec Smart Switch 6 with ISY
​The ISY displays a device item called "energy meter" with current current amps, current power watts, current voltage volts and total power kwh. Just tonight I pushed firmware 1.1 to two new ZW096-A02 units so the ISY could turn them on/off. The basic power energy features are still there for HS3 too, minus the bells and whistles. When the ISY catches up on support of the latest devices, I can always upgrade the firmware.
rljupiter, thanks for sharing this.  A few quick questions:
1.  how did you update the firmware of your smart switch 6 - did you use a minimote?
2.  how do you know what firmware  version you have in your smartswitch 6?
nwchicago
  • 1 year later...
I know this is an old thread but instead of starting a new one I figured I will continue from here.  I am on ISY v 5.0.15.  I have seen in one other thread that at v5.0.12 this switch was working and supported but I cannot say which version of software was installed on the switch itself.  I was just given one of these Aeotec Smart Switch 6 also known as ZW096-A02.  I started with an exclude and then an include of the device.  It took a while to complete the process and by the end I could see 4 new devices added.... And then the pop-up appeared
image.png.1839f70423db3751766846e0da740008.pngimage.png.2a5603a23fba4a0f1ed90585f889c509.png
I had to click the OK button 16 times to get rid of it and now as I move between the nodes I get the pop-up all all the nodes. As I step through each of the nodes have information populated but I have no control over any of them.  It seems like the information in the Energy Meter is pretty accurate based on some tests I did.
Since it was a gift I will live with the  fancy "monitor" but I was wondering if somebody had found some workarounds to the issues. Is the only remedy still to load firmware v1.1 on the switch?
Thanks in advance
Leon
Edited by leonpc
delete duplicate image
