October 2, 200719 yr With X10 support now in the ISY-26, I'm considering introducing X10 back into my system - strictly for X10 RF devices. I currently have a V572A X10 transceiver (http://www.wgldesigns.com/v572.html) kicking around that I could use. One thing I'm not up for is troubleshooting and spending money to get my X10 powerline strength up to par. Am I correct in thinking that if I plug the V572A into the same outlet box as my PLM, that X10 powerline strength shouldn't be an issue? Since it will be so close on the powerline? What is everyone else doing? Thanks!
October 2, 200719 yr The only thing I have kept that is X10 is the little Infrared X10 Command Console IR-543. I have tried to get it working with my universal remote to trigger my movie time scene but so far I have not gotten it to work at all. I am trying to get it to work with it directly connected to the PLM at this time and will update when I get it working or not. If Receive X10 House Code 'A' Unit Code '1' Command '11 - Off' Then Set Scene 'Family Movie Time' On
October 2, 200719 yr I think that my PLM with its firmware 4a is having issues with the X10 stuff. It will do it one time then after that it does not work.
October 2, 200719 yr Have you tried again since the 2.4.9 drop? Back in 2.4.8 the X10 messages had the same problem as non-toggle buttons, but this has been fixed in 2.4.9.
October 2, 200719 yr I was one of the first on the new release so yes I did it this morning. Let me experiment some more and make sure I am correct.
October 3, 200719 yr Author Wow, this actually has me pumped. I had pretty much given up on X10 stuff in my home. I plugged my V572A in to a plug close to the ISY-26, setup a couple of test triggers, and it's working great! I also plugged in my X10 IR bridge to a different outlet, and it tests great as well. This opens up a whole world of inexpensive X10 RF devices I could use. I now have use of my X10 keychain controls & palm pads again, and can start experimenting with X10 motions! However - I want to put it on record here that I vow not to go down the bumpy road of X10 powerline devices. I don't have energy or desire to deal with any issues that crop up. I vow to only use RF! Probably. Maybe.
October 3, 200719 yr I agree that my Pronto TSU7000 -> IR543 -> ISY -> Insteon works great! I used the X10 IR remote to learn the codes to my pronto. With the pronto's RF -> IR extender, I don't even point the pronto ... I can walk around the house firing off different scenes in the ISY from my pronto touch screen. (Including X10 in the ISY was the tipping point for my ISY purchase! My outdoor hawkeye motion sensors work again too!) Cheers! ~shawn
October 3, 200719 yr Author (Including X10 in the ISY was the tipping point for my ISY purchase! My outdoor hawkeye motion sensors work again too!) I agree. When people were requesting X10 support, I thought it was a waste of time. Now that it's implemented I think it's great.
October 4, 200719 yr In the next drop, you can log to the java console the key presses/X10 messages received by ISY from the PLM. This should help diagnose problems with your programs vs. problems with the network. On a side note ... Looking for opinions on displaying X10. We currently have the format in Program B, but I prefer Program A. I just wanted to get a couple of opinions before changing it. Program A If ( X10 'A.1.3 - On' is Received Or X10 'A.2.3 - On' is Received Or Control 'Keypad' is switched On ) And X10 A.1.11 - Off is not Received And X10 A.2.11 - Off is not Received And Control 'Keypad' is not switched Fast On Then Send X10 'C.4.3 - On' Set '0A.B9.44.1' On Else Set '0A.B9.44.1' Off Send X10 'C.4.11 - Off' Program B If ( X10 House 'A' Unit '1' Command '3 - On' is Received Or X10 House 'A' Unit '2' Command '3 - On' is Received Or Control 'Keypad' is switched On ) And X10 House 'A' Unit '1' Command '11 - Off' is not Received And X10 House 'A' Unit '2' Command '11 - Off' is not Received And Control 'Keypad' is not switched Fast On Then Send X10 House 'C' Unit '4' Command '3 - On' Set '0A.B9.44.1' On Else Set '0A.B9.44.1' Off Send X10 House 'C' Unit '4' Command '11 - Off'
October 4, 200719 yr Author I think either is fine. If it saves some memory in the ISY-26, I would certainly go with Program A. Or, maybe something like this would be a bit easier to read: If ( X10 'A.1.3(On)' is Received Or X10 'A.2.3(On)' is Received Or Control 'Keypad' is switched On ) And X10 A.1.11(Off) is not Received And X10 A.2.11(Off) is not Received And Control 'Keypad' is not switched Fast On Then Send X10 'C.4.3(On)' Set '0A.B9.44.1' On Else Set '0A.B9.44.1' Off Send X10 'C.4.11(Off)'
October 4, 200719 yr I would prefer format 'A'. I would not object if it was even simplified more: from: Or X10 'A.2.3 - On' is Received to: Or X10 'A.2 - On' is Received Just as long as the meaning of the code (On, Fast On, Off, etc.) is included.
October 4, 200719 yr I agree with MikeB ... I'm not familiar with the details of X10, but I assume that the final number correlates to the command (3=ON, 11=OFF) if this is the case, MikeB's "connects" the final 3 with it's definition better. 'A.1.3 - On' this makes it seem like A.1.3 is a device that then sent an On command. Really (i think) it's A.1 that sent a 3 command, with 3 defined as "On". Taking it further, the 3 is not of use to me personally, so I'd be fine with 'A.1(On)' 'A.1(Off)' etc .. just my $.02 And of course, if my initial assumption isn't correct, ignore this completely.
October 4, 200719 yr I would like to keep the command number in there, just in case people are debugging a program and need to know the actual number. We only store the A.1.3 on the box itself, so there is no memory problem with longer messages. Based on your ideas, I think the following is probably the best way to go: If X10 'A.2 - On (3)' is Received Or X10 'A.2 - All Lights On (5) ' is Received Then Send X10 'C.4 - On (3)'
October 5, 200719 yr Sorry for the late input. In the X-10 world, the 'group' (housecode) is designated by a letter, and the 'unit' by a number, thus making them easy to distinguish; the 'control' is usually written as a word, but internally represented by a number. I agree with Chris that the control code is needed for debugging. But, the English word is easier for the user to understand, so I would prefer something like this: If ( X10 'A1/On (3)' is Received Or X10 'A2/On (3)' is Received Or Control 'Keypad' is switched On ) And X10 'A1/Off (11)' is not Received And X10 'A2/Off (11)' is not Received And Control 'Keypad' is not switched Fast On Then Send X10 'C4/On (3)' Set '0A.B9.44.1' On Else Set '0A.B9.44.1' Off Send X10 'C4/Off (11)'
December 24, 200718 yr Wow, this actually has me pumped. I had pretty much given up on X10 stuff in my home. I plugged my V572A in to a plug close to the ISY-26, setup a couple of test triggers, and it's working great! I also plugged in my X10 IR bridge to a different outlet, and it tests great as well. This opens up a whole world of inexpensive X10 RF devices I could use. I now have use of my X10 keychain controls & palm pads again, and can start experimenting with X10 motions! However - I want to put it on record here that I vow not to go down the bumpy road of X10 powerline devices. I don't have energy or desire to deal with any issues that crop up. I vow to only use RF! Probably. Maybe. Mike, I'm trying to decide which way to go for IR interface. I'm thinking about getting a Harmony 1000. I could trade up to 99 in a month or so, or I could wait for the IRLinc, which I think will take longer than they say and I don't even know if it will trigger ISY programs. If I make the jump now, do you know what the most reliable system is. I would assume it would involve X10 at this point and thus require an IR extender to get the X10 signals close to the ISY, but what is the best IR>X10 bridge that will work with the Harmony, do you think? Thanks!
December 24, 200718 yr Author Mike, I'm trying to decide which way to go for IR interface. I'm thinking about getting a Harmony 1000.I could trade up to 99 in a month or so, or I could wait for the IRLinc, which I think will take longer than they say and I don't even know if it will trigger ISY programs. If I make the jump now, do you know what the most reliable system is. I would assume it would involve X10 at this point and thus require an IR extender to get the X10 signals close to the ISY, but what is the best IR>X10 bridge that will work with the Harmony, do you think? Hey Jim - I'm using my Harmony 880 with the ISY-99's IR, and love it. Very responsive, very reliable, very flexible. If you're considering moving up to the ISY-99, you might want to check and see if UDI still has any beta units left for sale. Otherwise, I think the only shipping IR interface would be the X10 IR543. I actually have one up for sale on Cocoontech. If you can get a consistent powerline X10 signal to your PLM/ISY-26, it should work well - but with a second or 2 delay compared with a native Insteon solution.
December 24, 200718 yr I'd rather not fool with the beta for now, as I am out of town a lot. I am assuming I would just use the 543 as the IR>X10 bridge? I have a branch in my family room that is pretty solid. I have an X10 16 button ultrasonic controller/remote (you heard me right!) that started out 100% but lately has been getting intermittent in reliability to the ISY. But the ISY X10 signals coming back to that same branch which control the fireplace and digital picture frame are still 100%. So what you are saying is that I can try replacing the 16 button controller with the 543. If it is reliable, fine, if not reposition it very close to the PLM and use an IR extender (powermid or whatever) to get the Harmony signal there? Does it only do one house code? So that would be only 16 controls, unless you split them up. Does the Harmony have a built-in code set or is it best to 'learn'? I don't mind the second or two delay as long as I know it's going to work. Thanks for the help.
December 24, 200718 yr Author I'd rather not fool with the beta for now, as I am out of town a lot. To be honest, I think a beta ISY-99 would probably be more stable than an X10 solution. Keep in mind that the ISY-99 is pretty much an ISY-26 Part II - pretty much the same firmware, but with the addition of IR support. And IR control for me has been rock solid. So what you are saying is that I can try replacing the 16 button controller with the 543. If it is reliable, fine, if not reposition it very close to the PLM and use an IR extender (powermid or whatever) to get the Harmony signal there? Yes, that sounds right. Does it only do one house code? So that would be only 16 controls, unless you split them up. You select the house code via a dial on the unit. The device has built-in hard buttons you can use to send unit codes 1-8. However, the IR port will accept unit codes 1-16. I'm not sure if you can use an IR remote to send house codes other than what's currently selected. So you may be right about the 16 code limit. However, I'm pretty sure I've used it in the past with various house codes on a single remote/IR543. Does the Harmony have a built-in code set or is it best to 'learn'? My Harmony 880 has the IR543 in its database. I don't mind the second or two delay as long as I know it's going to work. If it's important to you, you may want to look into how bright/dim commands would work. That could be an issue.
December 24, 200718 yr Does it only do one house code? Jim, the IR543 does only a single housecode. The IR543AH will do all 16 housecodes, but is much more expensive. Smarthome has the former for $30, but doesn't have the latter (that I could find). AutomatedOutlet has the former for $20, and the latter for $90.
December 24, 200718 yr Yeah, $90 is a bit steep for something I may toss if/when I go to 99. Mike has a 543 for $12, I wouldn't feel so bad.
December 24, 200718 yr Yeah, $90 is a bit steep for something I may toss if/when I go to 99. Mike has a 543 for $12, I wouldn't feel so bad. Jim, go for it! If you wish to use it just for your home theatre room, 16 codes (one housecode) may be more than enough. If you find later you want more, well $12 wasn't too steep an investment.
December 24, 200718 yr Author Jim, the IR543 does only a single housecode. The IR543AH will do all 16 housecodes, but is much more expensive. Smarthome has the former for $30, but doesn't have the latter (that I could find). AutomatedOutlet has the former for $20, and the latter for $90. Huh.... I read up on it, and confirmed what you wrote - but I could have SWORN when I was using this I had my theater lights on A1 and A2, and my driveway lights on B1 and B2 and I was able to control them through my Harmony remote without flipping the house code on the IR543. If I had time I'd set it up again to verify.... but mine definitely says just IR543 on the bottom.
December 24, 200718 yr Mike, the used 2440 you have, are there any firmware issues with the age? Were there any revisions since you bought that one? Do you have a paypal account? Thanks.
December 24, 200718 yr Author Hey Jim - I'm not aware of any firmware issues with RemoteLincs. All of mine seem to performed equally, and I've never read of any substantial changes. The used one does, however, say rev 0.92. My new one says rev 1.0. Yes, I do have a PayPal account. Feel free to PM me.
