ISY Data - Addition - Month As An Integer
Is it possible to get an additional value added for month as an integer?
I have a program that used the interger month value in ISYLink that does a comparison to another variable that is set elsewhere, which I can't do with the String-based value.
I can work around it by creating a bunch of programs to set a month variable based on the String-based value, but would be much cleaner and easier if I could just pull it from NodeLink.
If you are running v5.x the month is another system variable on a pulldown programming menu.
I can set the value of a variable to the month using the system pulldown, but I don't appear to be able to compare the value of a variable to the system month (there is no pulldown for system when doing a comparison). ie. there's no system pulldown for Condition, only for Action.
I worked around it with the following program:
Set Date.Current_Month
        'ISY Additional Data' Month is January
     Or 'ISY Additional Data' Month is February
     Or 'ISY Additional Data' Month is March
     Or 'ISY Additional Data' Month is April
     Or 'ISY Additional Data' Month is May
     Or 'ISY Additional Data' Month is June
     Or 'ISY Additional Data' Month is July
     Or 'ISY Additional Data' Month is August
     Or 'ISY Additional Data' Month is September
     Or 'ISY Additional Data' Month is October
     Or 'ISY Additional Data' Month is November
     Or 'ISY Additional Data' Month is December
        $Date.Current_Month  = [Current Month (Jan=1, Feb=2, etc.)]
And then do my comparisons against $Date.Current_Month. It's a little hokey, but it seems to work.
Edited by giesen
My other concern is that if the time on the NodeLink server is ahead of ISY by even a second, then the NodeLink server's Month variable will trigger the program, but the ISY will still set $Date.Current_Month to the old month. And because it's only triggered once a month, it would always be 1 month behind. I guess I could put a wait in there, but that's even more hackish.
Edited by giesen
This replacement program will probably solve my last concern more cleanly (although still not ideal):
        Time is 12:00:00AM
Basically every day at midnight (ISY time) it will set $Date.Current_Month to the current month (ISY time)
Edited by giesen
Here is the gadget I use to set MM.DD. I try to kick it a few times per day just in case it stalls for some reason.
Set MM.DD - [ID 00B8][Parent 0006]
        Time is 12:00:01AM
     Or Time is  3:00:01AM
     Or Time is  6:00:01AM
        $sISY.DayOfWeek Init To [Current Day of Week]
        $sISY.DayOfWeek  = [Current Day of Week]
        $sISY.DayOfMonth Init To [Current Day of Month]
        $sISY.DayOfMonth  = [Current Day of Month]
        $ISY_Date.scratchpad  = [Current Day of Month]
        $ISY_Date.scratchpad /= 100
        $ISY_Date.scratchpad += [Current Month (Jan=1, Feb=2, etc.)]
        $sISY.MM.DD Init To $ISY_Date.scratchpad
        $sISY.MM.DD  = $ISY_Date.scratchpad
Then I use it as a year wildcard for programs like this that have to work every year without editing.
Xmas Lights.road trees - [ID 000A][Parent 00C0]
             $sISY.MM.DD >= 11.15
         And $sISY.MM.DD <= 1.09
         And (
                  On Sun, Mon, Tue, Wed, Thu
                  From    Sunset  + 15 minutes
                  To      10:20:00PM (same day)
               Or On Sat, Fri
                  To      12:20:00AM (next day)
     Or (
             $sISY.MM.DD >= 12.23
         And $sISY.MM.DD <= 12.26
         And From    Sunset  + 15 minutes
             To      Sunrise + 15 minutes (next day)
        Set 'Foyer / Xmas Lights.road trees' On
        Wait  2 seconds
        Set 'Foyer / Xmas Lights.road trees' Off
        Wait  2 seconds
I believe UDI will be making some system variables into objective nouns, in later versions.
I wrote a script on my Pi that sets all those variables on my ISY.
Edited by builderb
NodeLink already does that quite well on a RPi.
I was trying to eliminate one link in the food chain though but the RPi is going to be partnered with ISY for some time yet.
I know, but I've been having trouble with nodes vanishing, so I'm holding off until that issue gets resolved. My script is my bandaid until then.
Plus it sounds like NodeLink is going on hiatus.
  • 4 weeks later...
Apparently you can set an integer variable to the value of ISY Additional Data - Month, just not do a comparison. So here's what I did and it seems to work:
Set Date.Current_Month - [ID 0063]
        $Date.Current_Month  = 'ISY Additional Data' Month
Then I can do my integer comparisons against $Date.Current_Month (a state variable I created). Obviously would be better to be able to do the comparisons directly to the value from the node server rather than having to have the extra step, but this seems to work quite well and is not as cumbersome as some of the other solutions.
