Zooz ZSE40 missing motion sensing subnodes
Some of my Zooz ZSE40 motion sensors are missing the motion sensing node. They all show up as,
  • Battery
  • Multilevel
  • Notify
  • Tamper
  • and few of them show an additional node, Motion.
ISY994 ZW PRO
Firmware v.4.5.4
Z-Wve 21100
Why does this happen? But more importantly, how do I fix this? What additional information can I provide to help diagnose the problem?
Here's the node information in for these nodes.
ZW086 shows motion sensor
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ] ZW086_1 uid=86 type=4.7.1 mid=265 tid=8225 pid=8449 model=0
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]    -  x5E  V0  ZWAVEPLUS_INFO
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]    -  x98  V0  SECURITY
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]    -  x86  V0  VERSION
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]    -  x72  V2  MANUFACTURER_SPECIFIC
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]    -  x5A  V0  DEVICE_RESET_LOCALLY
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]    -  x85  V2  ASSOCIATION
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]    -  x59  V0  ASSOCIATION_GRP_INFO
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]    -  x73  V0  POWERLEVEL
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]    -  x80  V0  BATTERY
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]    -  x71  V4  NOTIFICATION
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]    -  x31  V7  SENSOR_MULTILEVEL
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]    -  x70  V1  CONFIGURATION
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]    -  x84  V2  WAKE_UP
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]    -  x7A  V2  FIRMWARE_UPDATE_MD
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]   sensorType=  1  scaleMask=  3  defScale=1
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]   sensorType=  3  scaleMask=  1  defScale=0
Sun 10/30/2016 16:12:13 : [ZW-SHOW         ]   sensorType=  5  scaleMask=  1  defScale=0
ZW096 does not show motion sensor.
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ] ZW096_1 uid=96 type=4.7.1 mid=265 tid=8225 pid=8449 model=0
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]    -  x5E  V0  ZWAVEPLUS_INFO
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]    -  x98  V0  SECURITY
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]    -  x86  V0  VERSION
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]    -  x72  V2  MANUFACTURER_SPECIFIC
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]    -  x5A  V0  DEVICE_RESET_LOCALLY
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]    -  x85  V2  ASSOCIATION
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]    -  x59  V0  ASSOCIATION_GRP_INFO
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]    -  x73  V0  POWERLEVEL
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]    -  x80  V0  BATTERY
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]    -  x71  V4  NOTIFICATION
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]    -  x31  V7  SENSOR_MULTILEVEL
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]    -  x70  V1  CONFIGURATION
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]    -  x84  V2  WAKE_UP
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]    -  x7A  V2  FIRMWARE_UPDATE_MD
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]   sensorType=  1  scaleMask=  3  defScale=1
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]   sensorType=  3  scaleMask=  1  defScale=0
Sun 10/30/2016 16:19:59 : [ZW-SHOW         ]   sensorType=  5  scaleMask=  1  defScale=0
Hi Win10IoT,
Try triggering the motion sensor, this may create the ISY node for you.  If it does not, delete all the ISY nodes for the device (do not exclude the device, just go to the device tree and delete them).  Following that, make sure the device is awake and then do a Z-Wave -> Tools -> Synchronize Nodes -> New & Deleted.  This will recreate all the ISY nodes for the device,
Thanks for the suggestion. I will try this out and update the thread.
Did you get all the nodes to work?  I am thinking about picking one of these up
Mike
​My apologies. I should have updated this thread sooner. I was busy trying to get other stuff working.
No, I could not get it working. The ones that do work and show up as motion sensors don't perform very well either; and not just with ISY. They have performance issues with ST as well. Very slow to detect and report motion. There is a noticeable delay triggering lights with this sensor. Other sensors are much snappier--AEON, EcoLink, etc.
