Using 2477D as a controller for outlet dimmer
OK, Another question.  I have installed a 2477d switch without a load connected.  I intend to use this as a controller for 3 insteon dimmable outlets that have lamps connected.  I have figured out how to control the outlets(lamps) if switch is "100%" or "off", but how do I write the program to control the lamps with the dimmer function.  Yes the outlets are dimmer versions.  Also, is there a way to get these lamps to come on randomly(individually) from SR-SS IF the switch is not "on"?  Thanks everyone.
Add the 2777D to a scene as a controller and add the three outlets to the scene as responder.
B.R.I.A.D.A.
Best regards,
Gary Funk
Well, first stop yelling.
Second, see if you can find one of the outlets from the Administration Console.
B.R.I.A.D.A.
Best regards,
Gary Funk
Sorry Gary,
CAPS lock!
I got it to work.  I was adjusting the "ON" level.
Any idea how to randomly get the lamps to randomly come on and go off during night time hours?
Thanks again!
Make three more scenes and add a outlet to each scene. Then set programs to randomly turn any of the scenes on and off.
B.R.I.A.D.A.
Best regards,
Gary Funk
