James Peterson Posted November 19, 2016 Posted November 19, 2016 Just pushed a new update. I feel that we have cleaned up most of the serious ELK issues and would request that any other beta users that have been holding off to take a look. If everything goes well, I will hopefully be pushing this new update to live in the near future. Please report all bugs as always.
Jimbo.Automates Posted November 19, 2016 Posted November 19, 2016 None of my scene members showed up in a scene, did a refresh then they showed up. Sent from my Nexus 6P using Tapatalk
James Peterson Posted November 19, 2016 Author Posted November 19, 2016 None of my scene members showed up in a scene, did a refresh then they showed up. Sent from my Nexus 6P using Tapatalk Is this a new scene? had you made changes to this scene since the last time you used Agave? Agave buy design does automatically refresh is data every time you load the app after I learned there could be systems the size of yours out there in the world. It would be waste of a lot of data for every restart. So I elected for a self refresh option. I guess I could put it on a self delay of so many hours since last refresh.
Jimbo.Automates Posted November 19, 2016 Posted November 19, 2016 It was not a new scene, I checked 3 scenes and all had blank members. I had to do the refresh from the settings to get them. It may be possible that it was from upgrade to 5.0.4 but I did that a long time ago. Sent from my Nexus 6P using Tapatalk
Jimbo.Automates Posted November 19, 2016 Posted November 19, 2016 Just checked my Pixel C and scene members are also empty, but it is running 1.5.101 so not sure when this happened. Sent from my Nexus 6P using Tapatalk
MWareman Posted November 19, 2016 Posted November 19, 2016 One minor niggle. Been there for quite a while. When starting the app, and at the pin entry screen... You cannot then exit the app unless a valid pin is entered. If the back button is pressed, the regular exit dialog should be displayed.... You also probably shouldn't allow access to the app menu from the pin entry screen either.... I can reliably get the app to crash by starting it. On the pin entry screen I hit the menu, the profile. I think there may be a pin bypass somewhere buried here.... It likely needs some work. Michael.
MWareman Posted November 19, 2016 Posted November 19, 2016 Another minor UI improvement. On the Profile List screen - can you indicate the current profile, and suppress the delete button? I see you check for current profile when the delete button is clicked - but it would help the user out to have a visual indication on the screen... Michael.
MWareman Posted November 19, 2016 Posted November 19, 2016 In settings, I have 'Run' service in Background's unchecked, and 'Do not show exit confirmation'. If I go into 'Profiles' and add a new profile... Then switch to it.. I get to the page to configure the connection. If I hit 'Back', Agave exits leaving the background service running.... Either it needs to exit in accordance with the settings, or back should go back to the prior profile (which would make more sense in this case) Michael.
MWareman Posted November 19, 2016 Posted November 19, 2016 What is 'Require PIN' for? I set it to 4 mins, when I exit the app and reopen it immediately it prompts me again... If this is only supposed to work if the background service is allowed to run, the setting should be fixed to 0 and disabled if the background option is not enabled. (Sorry for the multiple posts! Just had 10 mins to do some testing this morning...)
James Peterson Posted November 19, 2016 Author Posted November 19, 2016 One minor niggle. Been there for quite a while. When starting the app, and at the pin entry screen... You cannot then exit the app unless a valid pin is entered. If the back button is pressed, the regular exit dialog should be displayed.... You also probably shouldn't allow access to the app menu from the pin entry screen either.... I can reliably get the app to crash by starting it. On the pin entry screen I hit the menu, the profile. I think there may be a pin bypass somewhere buried here.... It likely needs some work. Michael. I'll work on it. Another minor UI improvement. On the Profile List screen - can you indicate the current profile, and suppress the delete button? I see you check for current profile when the delete button is clicked - but it would help the user out to have a visual indication on the screen... Michael. sure. In settings, I have 'Run' service in Background's unchecked, and 'Do not show exit confirmation'. If I go into 'Profiles' and add a new profile... Then switch to it.. I get to the page to configure the connection. If I hit 'Back', Agave exits leaving the background service running.... Either it needs to exit in accordance with the settings, or back should go back to the prior profile (which would make more sense in this case) Michael. I'll see if I can figure it out. What is 'Require PIN' for? I set it to 4 mins, when I exit the app and reopen it immediately it prompts me again... If this is only supposed to work if the background service is allowed to run, the setting should be fixed to 0 and disabled if the background option is not enabled. (Sorry for the multiple posts! Just had 10 mins to do some testing this morning...) I was supposed to be for minimizing or app out of focus. I can add an option for exited as well it that is most appealing.?..?
MWareman Posted November 19, 2016 Posted November 19, 2016 I was supposed to be for minimizing or app out of focus. I can add an option for exited as well it that is most appealing.?..? Ahh, that makes sense... If it's easy to extend it to exiting as well, it would be consistent with other instances of this feature I've come across... Thanks!
James Peterson Posted November 19, 2016 Author Posted November 19, 2016 Ahh, that makes sense... If it's easy to extend it to exiting as well, it would be consistent with other instances of this feature I've come across... Thanks! I think I have made it through your honey do list...
James Peterson Posted November 20, 2016 Author Posted November 20, 2016 1.5.103 Beta pushed a new update adding a few security fixes and tweaks.
James Peterson Posted November 20, 2016 Author Posted November 20, 2016 1.5.103 Beta pushed a new update adding a few security fixes and tweaks. I guess I pushed an update feature that does not work right. I am readying a revert patch asap.
G W Posted November 21, 2016 Posted November 21, 2016 1.5.103 is working. I'm still looking at a way to tell what has caused the Violated area so you can report better information. B.R.I.A.D.A. Best regards, Gary Funk
MWareman Posted November 21, 2016 Posted November 21, 2016 James, got an update earlier. Happy to report I can now exit from the pin entry screen. However, it leaves the background service running in the background, even though I have that option unchecked in settings.
James Peterson Posted November 21, 2016 Author Posted November 21, 2016 James, got an update earlier. Happy to report I can now exit from the pin entry screen. However, it leaves the background service running in the background, even though I have that option unchecked in settings. Can anyone else confirm this? Not like I don't believe your MWareman, but it seems to work on this end.
G W Posted November 21, 2016 Posted November 21, 2016 Can anyone else confirm this? Not like I don't believe your MWareman, but it seems to work on this end.It seems to work correctly on my 6P. I'm Gary Funk and I approved this message.
gweempose Posted November 21, 2016 Posted November 21, 2016 Not really a bug per se, but a minor UI glitch. The name of the zone bumps up against the sensor type:
James Peterson Posted November 21, 2016 Author Posted November 21, 2016 Do you think just a bit more vertical space or truncating the amount of given space to the fields would be preferred? Not really a bug per se, but a minor UI glitch. The name of the zone bumps up against the sensor type:
gweempose Posted November 21, 2016 Posted November 21, 2016 Do you think just a bit more vertical space or truncating the amount of given space to the fields would be preferred? My preference would be to keep all the information and just adjust the vertical spacing a bit.
MWareman Posted November 22, 2016 Posted November 22, 2016 Not sure if I got an intermediate version - it's now saying to hit back twice to exit (didn't ask that before) and if I do it exits properly. Sorry for the false alert! Michael.
MWareman Posted November 22, 2016 Posted November 22, 2016 Do you think just a bit more vertical space or truncating the amount of given space to the fields would be preferred?My feeling is a bit more vertical spacing will fix this. Michael.
