gbirk Posted November 19, 2016 Posted November 19, 2016 I just purchased the app. I was able to setup a profile and log into my ISY. All my lights, scenes and switches/dimmers showed up. Using the app, I am able to control Buld Devices. I have just over 2 dozen devices controled by dimmers and relays. Some work, others will only turn on and others have no control. Any suggestions?
James Peterson Posted November 19, 2016 Posted November 19, 2016 I just purchased the app. I was able to setup a profile and log into my ISY. All my lights, scenes and switches/dimmers showed up. Using the app, I am able to control Buld Devices. I have just over 2 dozen devices controled by dimmers and relays. Some work, others will only turn on and others have no control. Any suggestions? Odd. Can you give me an example of a device that does not work properly.? Sent from my Nexus 5X using Tapatalk I just purchased the app. I was able to setup a profile and log into my ISY. All my lights, scenes and switches/dimmers showed up. Using the app, I am able to control Buld Devices. I have just over 2 dozen devices controled by dimmers and relays. Some work, others will only turn on and others have no control. Any suggestions? Did you purchase or are you currently running the free trail period? Sent from my Nexus 5X using Tapatalk
gbirk Posted November 19, 2016 Author Posted November 19, 2016 A SwitchLic Relay and a SwitchLinc Dimmer. I purchased the full access level today.
James Peterson Posted November 19, 2016 Posted November 19, 2016 A SwitchLic Relay and a SwitchLinc Dimmer. I purchased the full access level today. Ok. Can you tell me more about what is not working now.? What is displaying on the screen? What response are you receiving? Screenshots? Sent from my Nexus 5X using Tapatalk
gbirk Posted November 19, 2016 Author Posted November 19, 2016 I have 12 devices that work. I can turn them on, off and dim with the app. I have 7 that I can turn on and dim, but not shut off. When I press off or double off, the light is still on but the app says it is off. I have 8 that when I press on or double on, nothing happens. The light is off and the app says off. If I go to the switch or log into the web interface using the isy's ip address (http://192.168.0.xxx)/WEB/udajax.htm) I can turn the light on and off.
James Peterson Posted November 19, 2016 Posted November 19, 2016 I have 12 devices that work. I can turn them on, off and dim with the app. I have 7 that I can turn on and dim, but not shut off. When I press off or double off, the light is still on but the app says it is off. I have 8 that when I press on or double on, nothing happens. The light is off and the app says off. If I go to the switch or log into the web interface using the isy's ip address (http://192.168.0.xxx)/WEB/udajax.htm) I can turn the light on and off. I need to know more about the devices that don't work. (Type/model/version) Is it possible for you to send me a node dump of a few of those devices? NodeDump
gbirk Posted November 19, 2016 Author Posted November 19, 2016 Thanks for your offer to help. I think my issue was actually related to the PLM. I did a restore modem (PLM) and everything seems to be working. Have a great weekend.
