Multiple light type control for dimming LED and Incandescent
Ajax
OK guys, I have multiple rooms with your standard can lights with incandescent bulbs, but also a fan (fanlinc) with LED light that does not like to dim too much. My question.The can lights + the LED fan light is on a single scene with dimmer switch for each room. Would it be possible to have the LED turn off for anything below 100% so if I want to dim my lights the LED turn off and the can lights dim?
I cannot imagine why not. Sounds like a simple program...
Status can lights not 100%
Turn off led light
Turn on led light
You would need to take the led our of the scene, also
I'm using a FanLinc with Sylvania dimmable LED bulbs. No problems, no flicker at even low levels. You may want to try a different brand LED bulb with your FanLinc.
Alas, you are always going to have a problem when you mix LEDs with incandescent on the same dimmer, or even if you mix brands of LEDs. Or even wattages of LEDs or specific products of a given brand.
Most people will find it disturbing when they turn off at different places on the dimming curve!
Experiment until you find something that is "less disturbing".
Otherwise, use a program as shown above.
Having at least one incandescent bulb on the same dimmer as LED bulb will nearly always eliminate flicker, but expect the dimming rate to be different--by a lot.
      380.1k
