Trying To Add Aeotec Siren
I'm attempting to add an Aeotec Siren to my network but several attempts have failed.
Here's what I have been doing.
1. Start Device Discovery in the Admin Console.
2. Plug in the Siren.
3. Press the button on the bottom of the siren.
When I press the button, the led light flashes on and off. After that the device finder doesn't find it.
I've reset the siren 2 or 3 times.
I've had the siren right next to the ISY.
What am I missing?
Thanks!!
Device discovery doesn't work for Z-Wave devices, Use the Z-wave menu. You may need to tap the button twice (double tap).
Edited by stusviews
I've been using the device discovery in the Z-Wave menu. It says its listening for Z-Wave devices to add to the network. I've tried double taps,long taps, short taps. Thanks for your suggestions Stu!!
Sometimes you need to exclude the device first--even if it has never been added. In fact, you may want to exclude the device twice.
Stu's magic worked again!!!
Thanks Stu!!
