Blackbird Posted November 29, 2016 Posted November 29, 2016 Just went to set my alarm with Agave and it came up with "Loading error. Please refresh data". The lights work but not the ELK. I reloaded Agave after clearing the cache and the same thing. I noticed a new update which I did but still the same problem. I also refreshed the data and still the same. Thanks
James Peterson Posted November 29, 2016 Posted November 29, 2016 Just went to set my alarm with Agave and it came up with "Loading error. Please refresh data". The lights work but not the ELK. I reloaded Agave after clearing the cache and the same thing. I noticed a new update which I did but still the same problem. I also refreshed the data and still the same. Thanks Press and hold the small Elk icon. It should have been explained in the tutorial showcase. Sent from my Nexus 5X using Tapatalk
Blackbird Posted November 29, 2016 Author Posted November 29, 2016 Before I could try that it all of a sudden started working. Not sure why
James Peterson Posted November 29, 2016 Posted November 29, 2016 Before I could try that it all of a sudden started working. Not sure why The app will automatically flush and reload all data if it has been over an hour since its load full check. I choose not to do a full load on every view to save on mobile data usage, but i wanted to give an option to do it manually. It should only be needed if changes are made to the ELK without the app running.
Blackbird Posted November 29, 2016 Author Posted November 29, 2016 When I had the problem, I pushed it but didn't hold it down I guess
