Posted November 30, 20168 yr Trying to figure out, given: -8-scene Mini Remote -LampLinc Smart Plug how I can use the same button on the Mini Remote to turn a lamp on and off. Can that be done? thanks, Andrew
November 30, 20168 yr Be sure, also, to configure mini remote to 8 scene version. (It can be configured in 4 scene, which would require different buttons Robin versus off.)
November 30, 20168 yr Author Thanks! I really need to read up on this. Add them both to a scene.I'm Gary Funk. Pay no attention to this message.
November 30, 20168 yr Make sure you leave the remote in its default *toggle* mode and not OFF vs ON only modes. LOL . . .
November 30, 20168 yr If you did not change the function of the buttons, then they'll behave as Keypad buttons do, each press alternates between On and Off.
November 30, 20168 yr Author Hey everyone, Did a factory reset before linking to the ISY, and I didn't change its setting after that. If you did not change the function of the buttons, then they'll behave as Keypad buttons do, each press alternates between On and Off. Make sure you leave the remote in its default *toggle* mode and not OFF vs ON only modes. LOL . . .
November 30, 20168 yr Hey everyone, Did a factory reset before linking to the ISY, and I didn't change its setting after that. And the result?
