stmrocket Posted December 18, 2016 Posted December 18, 2016 I have 2 SynchroLink modules for monitoring the status of my washer and dryer. These had worked fine for several years but a while back stopped sending status. I finally got around to troubleshooting them today and noticed that while the unit does not show status changes automatically, it will always report properly if I press Query. Is there a way to fix this? I am running 5.0.2 but this worked for a while after the upgrade so I don't believe that is the reason...
stusviews Posted December 18, 2016 Posted December 18, 2016 Try a factory reset on the Synchrolinc. If you make note of the settings first, then you won't have to go through the procedure to initialize it.
stmrocket Posted December 18, 2016 Author Posted December 18, 2016 Try a factory reset on the Synchrolinc. If you make note of the settings first, then you won't have to go through the procedure to initialize it. That fixed it! Thank you.
