Honeywell thermostat
Anyone know what a D2D Event error is?  The thermostat appears to function correctly, however, every query results in a communication error.   Quite honestly, I find the event viewer to be frustrating. Troubleshooting zwave problems is like trying to measure voltage without a voltmeter.   Greg
Sun 01/01/2017 12:40:26 AM : [ZWAVE-TX ZW028_1] [010900131C023104]...
Sun 01/01/2017 12:40:26 AM : [ZWAVE-RX        ] ACK
Sun 01/01/2017 12:40:26 AM : [ZWAVE-RX        ] [0104011301E8]
Sun 01/01/2017 12:40:26 AM : [ZWAVE-TX        ] ACK
Sun 01/01/2017 12:40:26 AM : [ZWAVE-RX        ] [010500134B00A2]
Sun 01/01/2017 12:40:26 AM : [ZWAVE-RX ZW028_1] [010C0004001C0631]...
Sun 01/01/2017 12:40:26 AM : [ZWAVE-PROCESS   ] Process value Sensor type=1 uomId=1 prec=2
Sun 01/01/2017 12:40:26 AM : [D2D EVENT   ] Event [ZW028_1] [ERR] [0] uom=0 prec=-1
Sun 01/01/2017 12:40:26 AM : [     ZW028_1]      ERR   0
Sun 01/01/2017 12:40:26 AM : [ZWAVE-TX ZW028_1] [010900131C024002]...
Sun 01/01/2017 12:40:26 AM : [ZWAVE-RX        ] [010500134C00A5]
Sun 01/01/2017 12:40:26 AM : [ZWAVE-RX ZW028_1] [01090004001C0340]...
Sun 01/01/2017 12:40:27 AM : [ZWAVE-TX ZW028_1] [010900131C024502]...
Sun 01/01/2017 12:40:27 AM : [ZWAVE-RX        ] ACK
Sun 01/01/2017 12:40:27 AM : [ZWAVE-RX        ] [0104011301E8]
Sun 01/01/2017 12:40:27 AM : [ZWAVE-TX        ] ACK
Sun 01/01/2017 12:40:27 AM : [ZWAVE-RX        ] [010500134D00A4]
Sun 01/01/2017 12:40:27 AM : [ZWAVE-RX ZW028_1] [01090004001C0345]...
Sun 01/01/2017 12:40:27 AM : [ZWAVE-TX ZW028_1] [010900131C024402]...
Sun 01/01/2017 12:40:27 AM : [ZWAVE-RX        ] [010500134E00A7]
Sun 01/01/2017 12:40:27 AM : [ZWAVE-RX ZW028_1] [01090004001C0344]...
Sun 01/01/2017 12:40:27 AM : [ZWAVE-TX ZW028_1] [010900131C024202]...
Sun 01/01/2017 12:40:27 AM : [ZWAVE-RX        ] [010500134F00A6]
Sun 01/01/2017 12:40:27 AM : [ZWAVE-RX ZW028_1] [01090004001C0342]...
Sun 01/01/2017 12:40:27 AM : [ZWAVE-TX ZW028_1] [010A00131C034302]...
Sun 01/01/2017 12:40:27 AM : [ZWAVE-RX        ] [010500135000B9]
Sun 01/01/2017 12:40:27 AM : [ZWAVE-RX ZW028_1] [010C0004001C0643]...
Sun 01/01/2017 12:40:28 AM : [ZWAVE-TX ZW028_1] [010A00131C034302]...
Sun 01/01/2017 12:40:28 AM : [ZWAVE-RX        ] ACK
Sun 01/01/2017 12:40:28 AM : [ZWAVE-RX        ] [0104011301E8]
Sun 01/01/2017 12:40:28 AM : [ZWAVE-TX        ] ACK
Sun 01/01/2017 12:40:28 AM : [ZWAVE-RX        ] [010500135100B8]
Sun 01/01/2017 12:40:33 AM : [ZWAVE-TX ZW028_1] [010A00131C034302]...
Sun 01/01/2017 12:40:33 AM : [ZWAVE-RX        ] ACK
Sun 01/01/2017 12:40:33 AM : [ZWAVE-RX        ] [0104011301E8]
Sun 01/01/2017 12:40:33 AM : [ZWAVE-TX        ] ACK
Sun 01/01/2017 12:40:33 AM : [ZWAVE-RX        ] [010500135100B8]
Sun 01/01/2017 12:40:38 AM : [ZWAVE-TX ZW028_1] [010A00131C034302]...
Sun 01/01/2017 12:40:38 AM : [ZWAVE-RX        ] ACK
Sun 01/01/2017 12:40:38 AM : [ZWAVE-RX        ] [0104011301E8]
Sun 01/01/2017 12:40:38 AM : [ZWAVE-TX        ] ACK
Sun 01/01/2017 12:40:38 AM : [ZWAVE-RX        ] [010500135100B8]
Sun 01/01/2017 12:40:43 AM : [D2D EVENT   ] Event [ZW028_1] [ERR] [1] uom=0 prec=-1
Sun 01/01/2017 12:40:43 AM : [     ZW028_1]      ERR   1
The Z-Wave boards in Honeywell Tstats are known to work themselves loose. On the back of the thermostat is a cover under which is the Z-Wave board. I think there's a hole in the cover. Get something to push down on the board through the hole. Of course the cover can be removed if you're very careful, it's just a couple of clips.
Yes, I've done that.  It is an odd way to connect a daughterboard.   I've had the whole darn thing apart.  I'm pretty confident it is connected because it somewhat functions.  It is just a weird error.   I've struggled with a lot of stuff like this.   You can find the error, but then you don't know what the heck it means or how to troubleshoot it.
