Z-Wave Garage Door Opener Suggestions?
I am looking for a Z-Wave GDO to attach to my Genie GDO system.
I would like to use ISY firmware 4.5.4 but also would like future compatibility to the v5 series firmware.
I have pretty much ruled out the idea of the IO Linc Insteon.
Any suggestions?
There are a few Z-Wave relay controllers on the market, mostly multi-channel.
Compatibility issues aside, few are as cost-effective as an IOlinc.
I've been happy using the Linear gd00z-1 device with 5.0.2 firmware on the ISY.  Make sure to enroll it as a secure device, and note that if you need a repeater it'll have to be secure-capable as well.  I modified the Genie wall-mounted button for the garage door opener so that the Linear device is in parallel with the button contacts - a little soldering but nothing difficult in any way.
Any suggestions?
Good call...
If you have an Elk, connecting the GDO to an Elk output works great (it's what I do, and it's far more secure than an IOLinc, and not subject to the infamous 'All On' issue).
