Is ny isy dead
I think my isy might have failed but I'm not positive how to tell for sure. I know it was working earlier as I was getting notifications earlier in the day. When I look at the isy it seems as if it's not getting enough power. The blue led is on but quite faint. Also the ethernet port link light is also flashing very faintly even when there is no cable connected. When I power valve the unit I don't see the typical leds lighting up just the blue power led which doesn't seem like it's as bright as should be. I'm not sure what else to do since I'm unable to connect to it and it doesn't seem to be booting up at all.
Sent from my SM-G920V using Tapatalk
Well I was able to locate a similar power supply and it was able to supply power to the isy and it booted up normally. Thankfully it's seems I just need a new power supply.
