How can set a timer for a device for a fixed on time?
Hi guys!
I am very new to all this and I thank you all very much for you help.
I was wondering how i could program a timer for a light.
I/E I run the program and it is set to turn a light on for say 5 min then shut it off?
I am very new at this only had the unit a few days.
Tony
Hi guys!
Tony
What action do you want to trigger the light, a specific time, a motion sensor, etc?
Hi guys!
Tony
Here is a really simple example:
Test - [iD 0016][Parent 0001]
        Time is  7:00:00PM
        Set 'Side Door' On
        Wait  5 minutes
        Set 'Side Door' Off
In addition to Bill Morrow (above), you can add specific days to your time (look for the options) and if you make sure your time zone and lat/long is set correctly you should also find
....sunset + 1 hour 15 minutes
I just wanted to run the program via my echo.
if i leave the if blank would that work?
is there a pdf on programing?
thanks everyone
There must be code lines in your program for it to perform anything.
The "If" section may be left blank.
To connect your Echo into ISY, it is easiest and most powerful to use the ISY Portal for $49 per two years.
Asking Alexa to turn the program name On will run THEN. Off will run ELSE. No condition (IF) is required. Here's an example:
Movie Time
        Set Scene 'LR / Scenes / LR Audio Power' Off
        Set Scene 'LR / Scenes / LR Movie Time' Off
        Run Program 'LR Begin Movie 1' (Then Path)
        Set Scene 'LR / Scenes / LR Movie Time' On
        Run Program 'LR End Movie 0' (Then Path)
Thanks guys!
I did not see the drop down menu, lots of options there!
works well!
Thanks guys!
works well!
Yup, you got some learnin' to do there boy! [emoji3]
It never stops. By the time you get confident with that you will bite off so much more!
It's not a diet. It's a lifestyle. [emoji3]
Sent from a tiny keyboard. Response may be brief.
