Zigbee frequency?
Hi I have the ISY 994I pro with the Zwave board added /installed.. I purchased some Osram strip lights and a smartthings hub.. the lights work thru the smart things hub.I added a smart things wall switch it works too..But, I wanted to get all working thru ISY..but it doesnt detect the osram lights..I am finding out they arent zwave but Zigbee..is there anything I can do to eliminate the smartthings hub?
Thanks, Dave
Sent from my SM-G930U using Tapatalk
Hello Dave,
The ISY Series Controller only supports the energy profile for ZigBee. It does not support the home automation profile of ZigBee. Lastly, you can only have one expanded daughter board which you have now which is Z-Wave.
My suggestion is to use IFTTT, Network Resource, etc to interface with the bulbs - assuming the bulb has a open API to do so.
Ok, thank you Teken.
There are multiple types of osram bulbs, but if they have zigbee they may be the lightify bulbs which last I knew could be added to the hue hub if you have that.
Of course they have taken away support and added it back for other non hue bulbs so YMMV.
