shannong Posted January 10, 2017 Posted January 10, 2017 <I already submitted this to bitbucket with debug and screenshot> I have Zwave tstats from 2Gig that previusly were fully functional (I think). However, I can longer change the set points with the up/down arrows. I can still change the mode and turn the fan on/off. I think the issue might be related to that the ISY does not have +1 or -1 set point functions for these like they do for the Insteon tstats. You can only manually pick the set point from a drop down. The ISY doesn't have +/-1. But I sure would love it if Agave did using local application logic.
James Peterson Posted January 10, 2017 Posted January 10, 2017 <I already submitted this to bitbucket with debug and screenshot> I have Zwave tstats from 2Gig that previusly were fully functional (I think). However, I can longer change the set points with the up/down arrows. I can still change the mode and turn the fan on/off. I think the issue might be related to that the ISY does not have +1 or -1 set point functions for these like they do for the Insteon tstats. You can only manually pick the set point from a drop down. The ISY doesn't have +/-1. But I sure would love it if Agave did using local application logic. Can't be too sure. Put the app in debug mode and send me a log after you mess with the IP and down control points. Maybe send me a node dump of the thermostat as well. I'll get it working. Sent from my Nexus 5X using Tapatalk
shannong Posted January 10, 2017 Author Posted January 10, 2017 Can't be too sure. Put the app in debug mode and send me a log after you mess with the IP and down control points. Attached the debug to the Bitbucket issue when I created it. I just shared it here to make it easier for others to sound off if they are/aren't having the same issue as I figured most are browsing Bitbucket issues.
