Weather Module Timing and Notification
wjoel
I would like to run the Weather Module on a timely basis and send notification if the Weather reaches a certain temp. I would like to delay any repeat notification so that I don't get flooded with emails. Any tips on how to program this in a program. I know it must relate to the if statement.
Current Logic which continues to run.
If Module 'Climate' temperature <= 20 F'
Then Send Notification All
Wait 4 Hours
I use one program that waits before sending the Notification. This way if the temperature is fluctuating emails aren't continually sent. That program is called by two other programs, one starts the timer and the other stops it. If you duplicate the Notification in the Else path you could have an email when it warms again.
Program 'Temperature Warning'
       Wait  15 minutes
       Send Notification to All
       Wait  15 minutes
Program 'Weather Cold'
       Module 'Climate' Temperature < 20 °F
   And Program 'Temperature Warning' is False
       Run Program 'Temperature Warning' (Then Path)
When the temperature falls
Only runs if it was warm during last check
Program 'Weather Warm'
       Module 'Climate' Temperature >= 20 °F
   And Program 'Temperature Warning' is True
       Run Program 'Temperature Warning' (Else Path)
When temperature rises
Only runs if it was cold during last check
Rand
This is better. One program sends an email when the temperature falls below the target, and stays below, for 5 minutes, the other sends an email when the temperature rises above the target with the same 5 minute buffer. One email is titled Temperature Cold and the other Temperature Warm.
Change the target temperatures if you like.
I can't seem to place more than two Code boxes in a post so I created several posts.
Program: Temperature Cold
       Wait  5 minutes
Cold = True
Warm = False
Program: Temperature Warm
       Wait  5 minutes
Warm = True
Cold = False
Program: Weather Cold
       Module 'Climate' Temperature < 32 °F
   And Program 'Temperature Cold' is False
       Run Program 'Temperature Cold' (Then Path)
       Run Program 'Temperature Warm' (Else Path)
Program: Weather Warm
       Module 'Climate' Temperature >= 32 °F
   And Program 'Temperature Warm' is False
       Run Program 'Temperature Warm' (Then Path)
       Run Program 'Temperature Cold' (Else Path)
When it warms
You can download the programs from here: Temperature.2009-02-06.10.53.39.zip.
Unzip the file and Import it to your ISY Programs folder.
Rand
I use a flag program, named "email notice sent", which is changed to true (then path), when my monitoring program sends an email. However, the monitoring program will only send the email if notification flag is false. The flag is changed to false once a day during daily query... You could change the frequency of resetting the flag to false... For me once a day works good because my program monitors for conditions that can yield snow...
Monitor:
       Module 'Climate' Dew Point (less than) 32 °F
   And Module 'Climate' Humidity (more than) 75 %
   And Program 'flag - SnowTextSent' is False
       Run Program 'flag - SnowTextSent' (Then Path)
Flag: (it's completely empty, just set to true or false by others)...
The 3:00AM Query All program:
       Time is  3:00:00AM
       Set Scene 'My Lighting' Query
       Run Program 'w - query thermostat' (Then Path)
       Run Program 'flag - SnowTextSent' (Else Path)
       Run Program 'flag-humidity mail sent' (Else Path)
      38.1k
      380k
