Alexa "away", door sensor return program
Now that I have the portal and Alexa working, I want to do this:
When I'm ready to leave the house, I'll Say "Alexa, turn Away lights on."
Then I'll open the front door, close it behind me, and leave.
Later, when I return, I'll want the scene I call "mood" to turn on when I open the front door.
Basically, Away tuns most of the lights off, and mood sets all the living room lights where I like them.
How can I program this?
I assume, I'll need to have the return home program be triggered by the door sensor.  In that case, the program will need to ignore the door sensor for a short period of time until after I leave the the house. Otherwise, as soon as I open the door to leave, the lights will turn back to mood.
~Jay
Define a State variable called $sHouse.away
Create several  programs to control the variable.
Program Leaving.vocal
...set $sHouse.away = 1  <----impending leaving
....set $sHouse.away = 0
Set up Portal vocals for this program and use
  • 'Alexa. Turn On Away' (run Then)
  • 'Alexa Turn Off Away'  (run Else)
To complete the task of setting the Away mode variable
Program Just leaving
....HDS is switched On/Off Not sure which way you want it.
AND
....$sHouse.away = 1  <----impending leaving
....set $sHouse.away = 2 <-----actually gone
Now you can write as many programs as you like based on this variable
Program Just Got Home
....$sHouse.away = 2
AND
Now your ISY knows if you are home or not.
Program Evening Lighting
....$sHouse.away = 0
AND
....From sunset
....To 11:00 PM
....turn on evening lighting
Program Shut All Off
....turn off all lights stuff
I think you will eventually find that you will need an additional variable called say.. $sHouse.vacation as they are different needs functions.
I don't set my heat back or HRV off unless I am going to be gone for more than 48 hours etc...
Create a scene with all the device you want turned off the a level of Off. If you want a few lights on when you leave, then set those to the appropriate On-level. The voice command is, "turn Dine Out on," and can be initiated by voice or a KPL button. The program also turns on the walkway lights and turns them off 4 minutes later.
Dine Out Front Door
        Control 'LR / Devices / LR Ceiling Light KPL 20 / LR Light KPLD Dine Out' is switched On
        Set Scene 'EX / Scenes / EX Walkway' On
        Set Scene 'House / Dine Out' On
        Wait  4 minutes
        Set Scene 'EX / Scenes / EX Walkway' Off
You can create a similar program to turn on mood lights when you return.
thanks for the detailed instructions!  I'll give it a try tonight when I get back home.  I'm sure I'll have some followup questions.
~Jay
