Can the ELK keyfob enable a program?
Blackbird
I use mine for that. I create an Elk Automation Rule than turns on an unused phantom output momentarily when Key Fob Button #4 is pressed. Then I write an ISY program that triggers on that output.
One limitation is that all key fob buttons are seen as one. So you can't have Button #4 on one key fob performing something different than Button #4 on a different key fob. Limitation of the Elk.
