Light switch not turning off? Turns on through sensor?
RichTJ99
Hi,
I am using a program with two motions sensors in the garage.  The idea is it is an occupancy sensor.
If either sensor is turned on, the light should turn on for 20 minutes then shut off.
Now it will turn on without issue but it will never turn off.  If i use the web interface it turns off no problem.  Is there something obvious wrong with the program?
Here is the program:
Garage 1+2 Motion - [ID 00C0][Parent 0010]
        Status  'Main Garage sensor1-Sensor' is On
     Or Status  'Main Garage sensor2-Sensor' is On
        Send Notification to 'Rich Email' content 'Garage Bay 1-2 Motion'
        Set 'Main: Garage Interior New' On
        Wait  15 seconds
        Wait  20 minutes
        Set 'Main: Garage Interior New' Off
        Wait  15 seconds
        Set 'Main: Garage Interior New' Fast Off
If one of the motion sensors turns off before the other, the program will trigger again and start the 20:15 minute wait all over again. So you could be waiting for up to 40 minutes for the lights to turn off. Both motion sensors would have to turn off at exactly the same time to do what you want, which is likely impossible.
Take out one of the sensors in the "if" statement to test if that is what's happening.
The problem is that the light never turns off.  It stays on until I shut it off via another scene (all off, downstairs).
Everytime i check on a camera or app the lights are on.
Any ideas why it wouldnt shutoff?
Each time either MS sends an "On" signal the timer restarts. Sending an Off should have no effect on the program. In any case, try using using "Contol" instead of "Status" and set the MS's to send on "On" only.
I think the problem is that the ISY re-evaluates the IF statement before executing the statement after the Wait command (it will go down the Else path) . I think you can split it into two programs. Or maybe turn it off on the else path, but I prefer to not use the else path very often.
IF
Motion triggered
THEN
Turn on lights
Send notification
Run "2nd program" then path
2nd program
THEN
WAIT 20 minutes
Turn off lights
I think stusviews identified the proper solution (use "control" versus "status").
Still, I am curious why you have the duplicate ON and OFF commands (separated by 15-sec waits)?
Hi,
I will give this a try.  I have a ton of devices & sometimes things 'miss' - ideally this will stop any missed off or on command.
Rich
      377.2k
