How to Change Elk Area in MobiLinc
I have the Elk module setup installed for my ISY.  I can see all of the areas, zones, etc... and I can arm/disarm the system through several programs with no problems.
My problem is with Mobilinc.
Under "Security" all I can see is "Area 2" of the Elk which is currently not in use by me.  I want to be able to view and arm "Area 1 / Home".
How can I switch the area in Mobilinc?  I couldn't find any option to change this anywhere.
I tried updating the ISY setting in Mobilinc a few times but that had no impact.
Got the answer from Wes @ Mobilinc:
“Found the workaround in the forum.  Open the ELK RP software, add areas 2 to 8, send to ELK system, then delete areas 2 to 8, send to ELK system.  Disconnect.  Open ISY admin, refresh topology.
That made Areas 2 to 8 disappear in the ISY.  Then I “updated” the MobiLinc which deleted the ghost areas leaving only Area 1.”
Worked like a charm!
