March 6, 20179 yr I was trying to add Insteon Model 2441ZTH Thermostat to my system and I get a New Device error. ( Cannot determine Insteon Engine ) See the attachement. Any suggestions? I have an access point within 10 feet of this thermostat. Thanks Edited March 6, 20179 yr by Michaelv
March 6, 20179 yr Since it is a battery operated module and is in a power saving mode. Did you wake it up by holding the Set Button until it beeps before trying to add it?
March 7, 20179 yr Author Yes, The ISY can see the Thermostat but shortly after I click on the finished button ( Link Devices) the error message comes up. MV
March 7, 20179 yr Yes, The ISY can see the Thermostat but shortly after I click on the finished button ( Link Devices) the error message comes up. MV Which firmware and UI are you running? Did you try moving the thermostat closer to a dual band device?
March 7, 20179 yr Author ISY 994i/IR Pro (1110) Firmware Insteon_UD994 v.4.5.4 ( 2016-09-30-16:12:25) UI Insteon_UD994 v.4.5.4 ( 2016-09-30-16:12:25) It is about 12 feet from a access point and closer to A few Dual band switches.
March 7, 20179 yr ISY 994i/IR Pro (1110) Firmware Insteon_UD994 v.4.5.4 ( 2016-09-30-16:12:25) UI Insteon_UD994 v.4.5.4 ( 2016-09-30-16:12:25) It is about 12 feet from a access point and closer to A few Dual band switches. The ISY is seeing the thermostat as it's detecting its firmware version. You might want to try a reboot on the ISY. Maybe also try a fresh set of batteries.
