March 21, 20179 yr I had a chance to look at a few different hardware revisions of the 2450 I/O Linc Modules.They use the same LNK354GN Switching Power Supply IC as the 2413 PLM and V2 Access Points.C7 was the part I found changed. Between hardware revisions.Hardware V1.0 0851:C3 6.8uf/250VC11 100uf/25VC8 10uf/16VC7 10uf/25V 25V rating was close to the 21VDC I measured on it.Hardware V1.8 1202:C3 6.8uf/250VC11 100uf/25VC8 10uf/16VC7 10uf/50V Mounted horizontally over PCB. As it was large to fit the boards hole spacing.Hardware V2.3 1430:C3 6.8uf/250VC11 100uf/25VC8 10uf/16VC7 220uf/50V Mounted horizontally over PCB. As it was large to fit the boards hole spacing.My thoughts are.In V1.8 C7 was changed to 10uf/50V for a better safety margin.In V2.3 C7 was changed to 220uf/50V to beef up the power supply. Updated incorrect revision from V1.6 to the correct V1.8 Change incorrect C ID for the 6.8uF/250V capacitor. Edited October 29, 20178 yr by Brian H
