March 27, 20178 yr I am trying to change one of the configuration parameter of the Zooz 4-in-1 Sensor, specifically the timer interval. The 4 sensors show in the admin console, but when I try to change time interval (parameter # 5) I get the following error message: "Z-Wave Command Failed". Values used on for parameter # 5: parameter size =1 and parameter value = 30 on the "Z Wave - Set Configuration parameters on the Administrative Console. Anybody else using this sensor?
March 8, 20188 yr Same problem here. Inability to set the resolution for reporting makes the sensor useless. Anyone using this sensor with ISY with success?
March 16, 20188 yr I see this thread is a little stale, just wanted to report that I was able to set parameters fine using 5.0.10. Make sure you wake up sensor.
