Error backing up ISY
You can reduce the incident of this happening by disabling all active programs and network resources and any inbound REST calls.
You have a few choices from reloading firmware in case the system is corrupted. To hard resetting the controller and then performing a restore.
The highest calling in life is to serve ones country faithfully - Teach others what can be. Do what is right and not what is popular.
Is it possible that the backup has links in its database to that missing 38828f.REC file so even a restore wouldn't fix it?
It's possible, that's why I offered the other two choices . . .
I ended up deleting the device that the REC file was associated with. Then re-added the device. That seemed to do the trick for now.
