How to set up a query on my thermostat to run every 10 minutes or so?
Unless I go into the console and query my thermostat every so often my thermostat reading is not accurate.  It may show 71 on the thermostat readout on the wall but on any devices it shows something different until I go into the console and query it.  Can anyone guide me to a place or help me to setup a program to get my thermostat to query every 10 minutes or so?  I have set up programs before but then I don't do it for several years and forget.  Thanks.
Edited by ingeborgdot
Well, I figured it out but is there any way to put the times in faster than adding each one individually?
Since we don't know what you wrote, it's hard for us to tell you how to make it better!
What, you mean you can't read my mind?  :mrgreen:
This is one of them.  Thermostat Query - [iD 0021][Parent 0001][Not Enabled][Run At Startup]
        Time is 12:00:00AM
     Or Time is 12:30:00AM
     Or Time is  1:00:00AM
     Or Time is  1:30:00AM
     Or Time is  2:00:00AM
     Or Time is  2:30:00AM
     Or Time is  3:00:00AM
     Or Time is  3:30:00AM
     Or Time is  4:00:00AM
     Or Time is  4:20:00AM
     Or Time is  4:40:00AM
     Or Time is  5:00:00AM
     Or Time is  5:20:00AM
     Or Time is  5:40:00AM
     Or Time is  6:00:00AM
     Or Time is  6:15:00AM
     Or Time is  6:30:00AM
     Or Time is  6:45:00AM
     Or Time is  7:00:00AM
        Set Scene 'Thermostat' Query
I tried to get this one to work but it doesn't seem to be working.
Thermostat test - [iD 0022][Parent 0001]
        From    12:00:00AM
        To      12:00:00PM (same day)
        Repeat Every  1 minute
iMeter Solo - [ID 0031][Parent 00C2][Not Enabled]
        From     8:00:00AM
        To       8:00:00AM (next day)
        Repeat Every  1 hour
           Set 'iMeter Solo' Query
This is a very basic program to accomplish the same just modify it to your specific needs. Please note the location of the repeat and the duration you can change to suite your needs.
Okay, this is what I tried but it just doesn't seem to work.
Thermostat test - [iD 0022][Parent 0001][Run At Startup]
        From     8:00:00AM
        From     8:00:00AM
Are you sure your Insteon network is properly coupled / bridged to reach the TSTAT? If you right mouse click on the program and invoke the *Run Then* what happens?
I figured out why it wasn't working properly.  I needed to set it to the time about now and when it hit that time it started.  So, it seems to be working properly now.  It would have started at 8 tomorrow if I would have set it to 8.  I just wasn't thinking properly.  It has now queried several times already so my temp is reading properly.
Yup, sorry forgot to tell you this earlier . . . Your next step is to enable *Run at startup* if you don't and the ISY Series Controller is rebooted it will not run as expected.
Edited by Teken
Thermostat Query - [iD 0022][Parent 0001][Run At Startup]
        From     1:00:00PM
        To       1:00:00PM (next day)
        Repeat Every  3 minutes
           Set 'Thermostat' Query
Do you think 3 minutes is too often?
Normally in a home the temperature doesn't drop very quickly so a query of every 5~10 minutes is fine. If you have lots of programs that are tasked to *Query* it can tie up the ISY Series Controller.
Only you know what types of programs are in place now so use your own good judgement.
