Schlage BE469 Random lock/unlock issues
My house is all insteon, but added a be469 z-wave lock to my garage/house door. I also added the Aeon siren for a repeater. Everything works fine but over the last 3 weeks, but I had it twice that the lock will just randomly lock/unlock over and over until you pull the battery. And I have no idea where to start and look. Does this sound like a lock issue or Isy? I did move the repeater tonight and healed the network and will see if that happens again. Just wanted to get another opinion.
I've never experienced that with any of my Schlage BE469 locks. Do you have any programs that control the locks? What firmware and UI are you using? After disconnecting the batteries, how long until the problem recurs?
Here is the info, I have a couple programs controlling it. Since it happened this first time and I pulled the batteries till the 2nd time this occurred  I would guess a week and a half.
 Firmware: Insteon_UD994_OADR v.4.5.4
UI: Insteon_UD994 v.4.5.4
Product: ISY 994i (1120)
-OpenADR (21010
-Z-Wave (21100)
-Portal Integration - UDI
Scene: KPL button controller and schlage lock responder.
Programs:
KPL Status - [iD 0041][Parent 000A]
        Status  'ZW 004 Schlage Door Lock' is Locked
        Set Scene 'Lock' Off
        Set Scene 'Lock' On
Lock - [iD 003E][Parent 000A]
        Status  'MasterBedroom KeypadA / MasterBedroom KeypadH' is Off
        Set 'ZW 004 Schlage Door Lock' Lock
Unlock - [iD 003F][Parent 000A]
        Status  'MasterBedroom KeypadA / MasterBedroom KeypadH' is not Off
        Set 'ZW 004 Schlage Door Lock' Unlock
I'm wondering if some of those "If Status 'MasterBedroom KeypadA / MasterBedroom KeypadH' " should be "If Control 'MasterBedroom KeypadA / MasterBedroom KeypadH'"?
Does the logs indicate the locks cycled from lock / unlocked? Have you changed out the batteries in the lock mechanism? What does the ISY Series Controller indicate as the voltage for the smart lock?
In you first scene:
        Status  'ZW 004 Schlage Door Lock' is Locked <--Is this the status of the lock or the status of the KPL button?
Also, as Kevin has pointed out, you may want to use control rather that status because if anything related or not changes the status of the button, the program will run even if the button is not pushed.
Teken I will have to check my logs next time (Or can you pull one after the fact?), Did not think of that!
In you first scene:
 That is the status of the lock since it can change if I manually unlock or lock it or using the keypad on the lock. I will experiment with the control. And report back
You can down load both system and error logs now. But if you have lots of activity like I do the logs may be full and stopped capturing the events. What is the voltage of the batteries noted by the controller and by DMM? [emoji847]
The highest calling in life is to serve ones country faithfully - Teach others what can be. Do what is right and not what is popular.
The batteries that came with it only lasted a couple weeks and I had one "lock/unlock" event then, and it stopped responding with unknown status. I changed the batteries and its holding around 98% the last week (which I had another event)
Will see if I can get anything from the error logs, wish I could remember when this was...my wife called and was very irritated with the lock so I just told her to unplug the battery, and never took note of the time or even the day...
Create a simple program that detects it the lock unlocks and then sends a notification. Then view the list of programs, sorted by time, that may have unlocked the door.
That.s the method I used to determine why the kitchen light seemed to randomly turn on B)
Ok it did it again this morning, I havent had time yet to change the programs hopefully this weekend, but below is the log,
Kitchen Mudroom
Status
0%
Fri 2017/04/14 07:08:33 AM
System
Log
Status
Unlocked
Fri 2017/04/14 07:08:36 AM
System
Log
Scene:Lock
On
100
Program
Log
Status
100%
Fri 2017/04/14 07:08:37 AM
System
Log
Device secure mode
0
Fri 2017/04/14 07:08:40 AM
Program
Log
Status
Locked
Fri 2017/04/14 07:08:58 AM
System
Log
Status
Unlocked
System
Log
Scene:Lock
Off
0
Program
Log
Status
0%
System
Log
Scene:Lock
On
100
Fri 2017/04/14 07:09:03 AM
Program
Log
Status
100%
System
Log
Device secure mode
1
Fri 2017/04/14 07:09:05 AM
Program
Log
Device secure mode
0
Fri 2017/04/14 07:09:08 AM
Program
Log
Status
Locked
Fri 2017/04/14 07:09:16 AM
System
Log
Status
Unlocked
System
Log
Scene:Lock
Off
0
Program
Log
Status
0%
System
Log
Scene:Lock
On
100
Fri 2017/04/14 07:09:17 AM
Program
Log
Status
100%
System
Log
Device secure mode
1
Fri 2017/04/14 07:09:23 AM
Program
Log
Device secure mode
0
Fri 2017/04/14 07:09:29 AM
Program
Log
Error
1
Fri 2017/04/14 07:09:45 AM
System
Log
System
-2
Device secure mode
0
Program
-1
Error
0
System
Log
Status
Locked
System
Log
Scene:Lock
Off
0
Program
Log
Status
0%
System
Log
Device secure mode
1
Fri 2017/04/14 07:09:54 AM
Program
Log
Edited by Ajax
