Lock programming
Hello -
I am wanting to program a light to come on when the Schlage lock is unlocked with the keypad. I noticed the option to do that if I use "Control" in the if line. But did I remember reading (i cant find it) that you have to use "Status" with a lock only? In that case the only option is just "Unlock". So that would mean the the light would come on when I unlock it from the inside. Ideally, I would like this to happen only when using the keypad.
My limited experience with Z-wave devices suggests that "status" is the only condition that can be use with some.  I have a switch, for example, that does not trigger "control" conditions.  Whether your particular lock is so limited...I suggest running your own experiment.  Create a program based on "control" of the lock and see if it triggers from an unlock event.  If not, try status.  Much of what I have learned has been by similar experiments.
Whether or not this could be limited to just keypad actuation is likely a feature of the lock, and not something that could be distinguished by the ISY separately from some other method (my best guess).
So I have had the same experience while experimenting with "Control" vs "Status". Status works - Control doesn't.
BUT I am now having trouble with it turning off after 3 minute. Do you see why this program wouldn't work? Specifically, why it wont turn off?
I have the lock set internally to re-lock after 30 seconds. Do I need to have that happen through the ISY?
Front Door Unlock Lightup - [iD 003B][Parent 0001]
        From     7:45:00PM
        To       3:00:00AM (next day)
    And Status  'ZW 002 Schlage Door Lock' is Unlocked
        Set Scene 'Dining Room' On
        Wait  3 minutes
        Set Scene 'Dining Room' Off
After 30 seconds, the lock re-locks itself, and Status changes to "Locked" so program is terminated before it can reach the end of the Wait time.
To confirm this, temporarily add "Set Scene 'Dining Room' Off" to the Else clause, you should see the light turn off when the lock changes state back to Locked.
If you disable the 30-second re-lock, you could get the results you are looking for with this program.
Front Door Unlock Lightup - [ID 003B][Parent 0001]
        From     7:45:00PM
        Wait  3 minutes
        Set 'ZW 002 Schlage Door Lock' to Locked
Comment
          (Make sure the command to lock the lock is the final line of the Then clause)
There are other ways to accomplish what you are looking for by using a second program.
Edited by KeviNH
Ahhh - great point. I always forget about the "Else" and what it can do for me.
I put all programming through the ISY for the light and relock - it works great! Thanks for the help.
One more question -  I dont want to trigger this program if the light is already switched on. Does the below look correct? Or do I need parens?
        From     7:45:00PM
    And Control 'Dining Room Switchlinc' is not switched On
        Wait  3 minutes
With my Kwikset deadbolt, I have some Control actions.   Here is my program that turns on a light:
         'Entry / Front Door Lock' is switched Alarm Unlocked by Keypad
    Or 'Entry / Kitchen Door Lock' is switched Alarm Unlocked by Keypad
        Run Program 'Home Lights' (If)
So if I wanted a time limit and light restriction, it would be:
Either Door PIN code 1 Copy - [ID 00B6][Parent 0080]
             From     7:45:00PM
         And 'Downstairs / Entry1' Status is Off
    And (
From 7:45:00PM
No need for parens ,a chain of "And" statements is fine.
In order to avoid to triggering this program if the light is already switched, I'd suggest changing "And Control 'Dining Room Switchlinc' is not switched On" to "And Status 'Dining Room Switchlinc' is Off".
I have been tinkering around with my system and checked on my schlage lock.  It DOES appear to trigger programs via "control" condition, and DOES appear to have ability to distinguish between manual and keypad actions.
I will try it again - mine did not last night. Status works good though. oberkc - do you have the 469?
Mine is the 468 "camelot". It is hard to imagine that they would be different other than cosmetically.
I will double check later to be sure.
So doing some more testing - the following program DOES work great (using Control) without the "and dining switchlinc is off". But when I put that back in, the light does NOT turn off after 15 seconds. What am I missing?
        From    10:45:00AM
    And Control 'ZW 002 Schlage Door Lock' is switched Unlocked by Keypad
        Wait  15 seconds
It doesn't turn off because the program triggers, begins running, and now the device 'Dining Room Switchlinc' is now on..
So now when it hits the wait, the program is reevaluated, and it reevaluates to false ( The "Status 'Dining Room Switchlinc is Off" is not true any longer).
You could have this program call another program to do what you want.
That's what I am going to do - forgot that a wait revaluates the program. Thanks!
I changed it to the following and it works great:
        From    10:45:00AM
        Run Program 'Front Door Unlock Light-up 2' (Then Path)
Front Door Unlock Light-up 2 - [iD 003E][Parent 0001]
        Wait  15 seconds
