Upgrade made easy!
Ok. I'm ready to make the change from an old ISY 26 to a new 99Pro. The old 26 and the new 99 have 2.6 as frimware. Would someone please list the details of my change-over. I.e., where to disconnect the old ISY, when to insert the new, and how to re-install the back-up. At what point should I install the 2.7 upgrade? If you could list these in the best order, I will make the plunge.
As a subnote, please tell me the best way to zero out the old 26 for use in my other home.
aLf
Hello aLf
Please see this Wiki page: Migrating_To_Your_ISY-99i. The upgrade to the ISY can be done after you restore your configuration.
The easiest way to reset your ISY-26 is to telnet to the device and issue a FR (factory reset) command.
Telnet_To_Your_ISY. The upgrade can be applied after the reset.
Note that there are different upgrade files for the 26 and 99i.
Rand
Rand:
I got the swap done, but how do I log back into it? How does the new 99 know its IP address?
aLf
