How do you delete the Java Cache in Vista?
START
CONTROL PANEL
PROGRAMS (only if not in Classic View)
JAVA
SETTINGS button
DELETE FILES button
In a Vista 64-bit environment:
START
CONTROL PANEL
VIEW 32-BIT CONTROL PANEL ITEMS
JAVA
SETTINGS button
DELETE FILES button
Ok Guru's.. Since upgrading, My XP machine will no longer see ISY in My Network Places. I can access it by typing the URL in, but no icons show. Is there a simple fix?
aLf
Sometimes the router has to be rebooted to see a new device.
Rand
Rand: Just re-booted the modem, no luck. Is there a WIKI link you can post that will help configure the 99 to internet access. Does it explain HTTPS and its use with the 99. Never had that with the 26.
aLf
This page Remotely_Connect_to_Your_ISY is a bit outdated as it references the old port numbers. The Wiki editing is broken right now so I can't change it. The ISY now uses ports 80 (http) and 443 (https) by default.
Rand
