Open Close Sensor - One Time Trigger
Hello everyone,
I am sure you guys can help, so thanks in advance.
I have the below program to run the fan in the bathroom when the shower door is open. The issue is, that I open the shower door, turn on the water, close the door and then a few moments later actually go into the shower.
I have the below program and I would like it to run on the first "open" scenario and ignore (for a time) the others. How do I do that? I notice I open and close open and close and the fan continues. Thank you
               Status Bath Entry is On
     AND  Status Sensor is On
             Set Fan On
             Wait 15 Minutes
            Set Fan Off
I Use Insteon Open Close sensor and switch and an ISY
Assuming that I understand your intentions, I suppose you could try something like:
if
status bath entry is On
and status fan is off
and control sensor is on
then
run next program (then path)
Next program (disabled):
if
nothing
then
set fan on
wait 15 minutes
set fan off
If you want to define a time other than 15 minutes to wait for the next fan trigger, a few other steps may be needed.
