new program
so, when I write a new program as below it does not start right away unless I force it to, so I assume it does not start until 5:30 the NEXT day?
From 5:30:00AM
To 10:15:00PM (same day)
Repeat Every 20 minutes
Wait 1 second
Send X10 'L2/On (3)'
Wait 2 minutes
Send X10 'L2/Off (11)'
From 5:30:00AM
Wait 1 second
Wait 2 minutes
Joe,
I think you have found a bug. If I reboot my ISY it correctly evaluates the program but when initially saved it is not run except at 5:30AM or 10:15PM.
I will forward this to the programmers.
Thank you,
Rand
Sub-Routine
If by reboot you power cycle to reboot I just checked, mine does not even run then only if I force it to run. Ii says next schedule is 10:15p
Sub-Routine
You are correct, I had to enable Run at Startup to see the program run when power cycling the ISY. I had just tried with the Reboot button on the Configuration panel.
I have added this to the Bug report.
Thank you again,
Rand
