Can one program turn a devices on & off?
Hi,
I am trying to use a program for Echo.
Living Room Program:
Turn Light 1 - Fast On
Turn Light 2 - Fast off
Is there a way for me to use a single program to alter the lights state?
So if the light is off, saying turn on will run the program, or if the light is off, turning the program off will run the program (changing the lights to the opposite state)?
Basically I am running out of links on my PLM so I am trying to get rid of a scene - plus the devices seem to work for fast on only (different issue).
Rich
Hi,
Rich
Turn On and Turn Off run the same program. On runs Then section. Off runs the Else section.
....---    = nothing required for Echo vocals
....turn light On
....Wait 6 hours = lest yee forget.
....turn light Off
...turn light Off
You can turn on scenes or use direct commands for any quantity of devices. Slight ramp rates cover up different reponse times, to the human eye.
Thanks - that is great!  I run into issues where due to a communication problem something doesnt run as expected.  Is there a better way to 'repeat'?  I want a triple on & a double off - is there a better way?
Outside Echo
        Set Scene 'Scenes / Outside' Fast On
        Wait  8 seconds
        Wait  8 seconds
        Wait  3 hours
        Set Scene 'Scenes / Outside' Fast Off
        Wait  8 seconds
        Wait  8 seconds
        Repeat 3 times
           Wait  8 seconds
        Repeat 0 times   <--- this keeps the 3 hour wait from repeating
           Wait 3 hours
        Repeat 2 times
           Wait  8 seconds
Edited by stusviews
        Repeat 3 times
           Wait  8 seconds
           Wait 3 hours
        Repeat 2 times
           Wait  8 seconds
...Repeat 0 times
may have undetermined results.
You should use
...Repeat 1 times
as a UDI documented method.
https://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Action
I am curious - if i wanted a button to do the same thing - i could duplicate the program (which I did).
I have it
If control keypad A is on
Off doesnt seem to run else.  Pressing A runs the "Then" (when its lighted), pressing "A" again to turn it off doesnt do anything?
Rich
I have it
Rich
Control devicename is switched On is not ever false if it causes the re-evaluation of the logic in that program.
Control devicename is switched On calls the attention of the ISY logic engine upon receiving the On signal from a device, so while the line  is being evaluated it is always True = running Then.
Statuses have two states, usually On and Off.
Control devicename is switched ON has two states = active and not-active.
Control devicename is switched Off has two states = active and not-active. Note two different signals to detect
Now just to complicate things. :)
...control devicename1 is switched On
...AND
...control devicename2 is switched On
        can never be True = never run Then.  While one line is being evaluated, due to it triggering the evaluation, the other line will always be False (at that time) and the combo will run Else.
So there are two ways to do this.
...status of devicename is On
....set light On
....set light off
....control devicename is switched On
AND
....control devicename is NOT switched Off
....set light On
....set light Off
...Repeat 0 times
You should use
...Repeat 1 times
My experience is that Repeat 0 times after a block of Repeat x times causes the statements that follow to run once (i.e, zero repetitions). Repeat 1 time causes them to run twice (one repetition).
It's a syntax error (grammaro) that has existed since Repeat was added to the ISY repertoire.
....Repeat 1 times
means execute once only.
I was using it in a few programs only to find out it had some problems. I don't recall what the problems were now. The discussion was  posted in a thread about a year back.
....Repeat 1 times
You are correct. You jolted my memory. I've used Repeat 0 times to emulate a REM.
V5 has comment lines but they take too much space vertically, so far. End of line remarks would be nice.
In particular, I mean REMing an executable statement so that it doesn't run when troubleshooting a program.
ahhhhh.. This would fit in with the checkbox at the end of every line idea, to enable/disable it. It would have a slightly different function in the If section.
