pilotgeek Posted July 23, 2017 Posted July 23, 2017 Preconditions: Portal access is not enabled Reproduction: Start Agave (you will be on the home page) Choose the hamburger menu -> Settings Scroll down to Enable Portal Access The checkbox will be unchecked but the text will read "Access Enabled". This will fix itself if you toggle on/off the access. But it will be broken again next time you go in. This falls firmly into the category of Unimportant, but is probably worth fixing next time you mess with settings. Regards, Neal
James Peterson Posted July 23, 2017 Posted July 23, 2017 Preconditions: Portal access is not enabled Reproduction: Start Agave (you will be on the home page) Choose the hamburger menu -> Settings Scroll down to Enable Portal Access The checkbox will be unchecked but the text will read "Access Enabled". This will fix itself if you toggle on/off the access. But it will be broken again next time you go in. This falls firmly into the category of Unimportant, but is probably worth fixing next time you mess with settings. Regards, Neal Thanks. I appreciate all the feedback.
James Peterson Posted July 28, 2017 Posted July 28, 2017 This should have been corrected in the last update.
pilotgeek Posted July 31, 2017 Author Posted July 31, 2017 This should have been corrected in the last update. Confirmed. It is fixed.
