Anything wrong with this technique?
Still a bit of a noob (few weeks with ISY). Anything wrong with temporarily disabling a program for a motion sensor so as not to get repeated alerts for a time period. The programs below work, I'm just wondering if it's a good technique or any pitfalls.
Away Motion
        $Away is 1
    And 'Entry motion E11' Status is On
        Send Notification to 'SMS Mike' content 'Open while away'
        Set 'Entry RC xceiver Can light E9' On
        Set 'Chime E16' On
        Run Program 'Enable entry motion' (Then Path)
        Disable Program 'Away Motion'
Enable entry motion
        Wait  1 minute and 30 seconds
        Set 'Entry RC xceiver Can light E9' Off
        Enable Program 'Away Motion'
Due to the sequential execution of statements, you may want to have the light turned on first.
I am not certain what you want these programs to do, but I see nothing inherently "wrong" with your programs.  If it works, even better.
As far as technique, why did you choose to split these two programs?  What about:
        $Away is 1
        Set 'Chime E16' On
        $Away is 1
        Set 'Chime E16' On
A program will not execute further lines after a Wait program  line, and disabling itself. Control has to be passed to another program during the disabled period.
Yep, learned early on through trial and error and reading the forums about the nuances of the wait command. As I understand the wait command also causes a reevaluation of the program execution status. My question was just about the technique of disabling/re-enabling a program within a program. In my short time, I haven't seen it used a lot in the forum examples.
Guess I should turn the light on first and get it on a fraction of a second sooner.
Thanks for the feedback so far,
Mike
TexMike, you are correct. A second program is needed if you want to disable and enable a program.
Cool.  I did not know that.
On the other hand, count me among those who disable and re-enable programs within a program.
You enable and disable a program within itself or you use a second program to disable and enable the first program?
The program can disable its self, then 2nd program is used to enable after a wait or another condition is met.
My concern was wrt/oberkc's post, one program or two?
I have, in the past, disabled programs within their own actions. I dont think I have any of those now, but do have currently programs that disable other programs.
