KeypadLinc button trouble
It had been some time since I refreshed my ISY and thought I'd factory reset ISY and Insteon devices.  I have a KPL 8 Button that had no problem adding back to ISY.  All buttons work normally, meaning I press the button and the LED lights up.  However, when looking at ISY, Buttons E-H do not register as being on?
In short, buttons E-H do light up when pressed, but ISY current state never goes to on?  Buttons A-D work normally....  lost on how to troubleshoot this issue?  Bad KPL?
In the admin console, click on help | about.  What firmware and UI are you running?
Silly question is this a 6 button KPL that was converted to a 8 and vice versa?
What does the ISY think this device is?
V 4.6.2 for both UI and Firmware
The KPL is and has always been an 8 Button KPL.  ISY thinks it is (2334-2) KeypadLinc Dimmer 8 Button v.43
Can you perform a device restore and let us know the result?
After a device restore from ISY...  it now works !?!   I find that strange considering a factory reset on KPL, but it is now all good.
Rock On . . . [emoji106]
It's really not that unusual for an Insteon device that's been functioning to at some time require a factory reset, sometimes twice. KPLs are among the most likely to need a reset.
