Can this be done?
Traditore
I have a very simple program that turns on a lamp plugged into an ApplianceLinc at a predefined time:
Time is 8:00:00AM
Set '0F.80.96.1/Torchère' On
That ApplianceLinc is also linked to a KPL button to manually turn on/off the lamp. The thing that bugs me is that the KPL button LED doesn't turn ON when the program runs every morning.
There must be a way for this to work. It seems simple but I can't figure out what to do.
Any ideas?
What I've done is create a scene with only the button/buttons used to control a light/appliance. Then I have a program that turns that buttons only scene on if the light or appliance status is on. Then for ELSE I have the scene turned off.
Example:
Status 'TV - Kitchen' is On
Set Scene 'Sync - Kitchen TV' On
Set Scene 'Sync - Kitchen TV' Off
My "Sync" scene has only the 4 KPL buttons that control the tv.
  Quote
Instead of turning on the ApplianceLinc in your program, turn on the entire scene which should contain both your ApplianceLinc and KeypadLinc button.
