James Peterson Posted September 14, 2017 Share Posted September 14, 2017 Not sure what these will be used for, but here is a little work in progress on the Agave app. Link to comment
LFMc Posted September 14, 2017 Share Posted September 14, 2017 Not sure what these will be used for, but here is a little work in progress on the Agave app. This is very cool if it is what I think it is. If these are for display of ISY variables, how does Agave know where to put the decimal point? Is this reading the ISY with firmware 4.x or 5.x? --Leon Link to comment
James Peterson Posted September 14, 2017 Author Share Posted September 14, 2017 5.x the ISY has a new precision variable that is used to implement decimal values on the ISY. Link to comment
LFMc Posted September 15, 2017 Share Posted September 15, 2017 5.x the ISY has a new precision variable that is used to implement decimal values on the ISY. That explains the decimal point. So when you create an Agave variable item on the Home Screen and you have it open to the Home Screen, do changes to the variable on the ISY get updated to the Agave screen and if so, how often do they refresh? If not, how do you get the displayed variables to refresh? Thanks, --Leon Link to comment
James Peterson Posted September 15, 2017 Author Share Posted September 15, 2017 The updates are automatic. The are updates though the data subscription through the ISY. As long as Agave is running the updates are almost instantaneous. Agave will also refresh all of the variables on restart. This is the same as any other object or device on the ISY. Link to comment
James Peterson Posted September 20, 2017 Author Share Posted September 20, 2017 I added the ability to set the precision from Agave. If anyone would like to test this new feature, I will be tossing it in the Beta channel for a while. If you don't want to test or don't want to risk possible variable corruption you may want to be sure that you have either exited or not in the beta program. Link to comment
LFMc Posted September 20, 2017 Share Posted September 20, 2017 I added the ability to set the precision from Agave. If anyone would like to test this new feature, I will be tossing it in the Beta channel for a while. If you don't want to test or don't want to risk possible variable corruption you may want to be sure that you have either exited or not in the beta program. Will this work with ISY 4.xxx firmware? Link to comment
James Peterson Posted September 20, 2017 Author Share Posted September 20, 2017 Will this work with ISY 4.xxx firmware?This depends on a new feature of 5.x. I have not seen any plans udi to add it to the 4x firmware. Sent from my Nexus 5X using Tapatalk Link to comment
LFMc Posted September 20, 2017 Share Posted September 20, 2017 This depends on a new feature of 5.x. I have not seen any plans udi to add it to the 4x firmware. Sent from my Nexus 5X using Tapatalk I understood that, it just looked from your screen shots that you were adding the "precision" after the integer variable arrived on the Agave app. which would be great for us 4.x users. Link to comment
LFMc Posted September 20, 2017 Share Posted September 20, 2017 I understood that, it just looked from your screen shots that you were adding the "precision" after the integer variable arrived on the Agave app. which would be great for us 4.x users. I see that you are pushing the precision back to the ISY with your app. I was hoping you applied precision to the displayed integer. Just wishful thinking. (-; Link to comment
James Peterson Posted September 21, 2017 Author Share Posted September 21, 2017 I see that you are pushing the precision back to the ISY with your app. I was hoping you applied precision to the displayed integer. Just wishful thinking. (-; Sorry, just updating a new feature in ISY 5.x This can all be done from the ISY in the new 5.x firmware when the variable is created or updated. Link to comment
James Peterson Posted November 4, 2017 Author Share Posted November 4, 2017 It appears that this feature may have affected 4.x users in a negative way in regards to variables. I am working on a fix. It should be out soon. Link to comment
