Problem with lights flashing and wont stop
I have a dimmer switch in the garage named "garage lights inside" and a 8 button keypad in the house named "Garage Lights KP C" .  Both control the interior lights of the garage.  Sometimes if I turn the garage lights on then off then on again with the dimmer, the lights start to flash and it gets into a never ending loop.  The only way to stop it is by disabling the "garage lights inside" dimmer then re enable it.
The "Garage Lights KP C" keypad and the "garage lights inside" dimmer are both a controller and responder for the "inside garage lights" scene which the "garage lights inside" dimmer is a part of.
Have I messed up something here?  usually it works fine but this looping has happened about a dozen times now.
Any suggestions?
I think you have a program that has a timer in it for those lights.
Sent from my Nexus 6P using Tapatalk
I have had a dimmer cycle between off and on repeatedly.  Is that what you are seeing?  In my case, it was a device failure.
Definitely check the program logs, however.  Maybe Gary Funk is correct and you have a program that has found itself in some sort of loop.
Look at your programs in the admin console and see which one is turning Red then green repeatedly. Right click it and then select Stop.
As per Gary above....This is usually caused by the same device in the If section as you are controlling.
I have fan that will sometimes get stuck in that loop. It's due to two programs fighting for control. Someday I'll actually find the cause.
Non dimmable CFLs or LEDs on dimmer module can cause that. I’ve also seen when CFLs start to fail. Look for carbon buildup on at the base of tubes and base is hot. I’ve seen unreliable Insteon communication when CFL start to fail, which clears up once I replace the offending CFL.
Now that LEDs have come down in price and reliability has improved, I’ve been slowly replacing CFL with LED. Also swapping out dimmer modules for relay modules. Only dimmers modules are on dimmable LED floods, which basically eliminate the heat load in a room vs a incandescent.
I just checked and yes, for some reason I had a program also controlling the lights.  I disabled it and will see if it stops happening.
Thanks guys
