Inovelli Z-Wave Dimmer module Parameter values
Hi Gary,
I'm not sure what could be going on here because setting a configuration parameter is quite straightforward in Z-Wave.  Looking at the output, its clear we are sending the correct command to the device, so I'm wondering if its getting there.
Are you able to set the value to zero?
I am able to set the value to 0 and 1 but not 2.  In SmartThings, I can set to 0, 1 and 2.
Eric, you saw my post     https://forum.universal-devices.com/topic/22536-inovelli-nzw37-2-channel-switch/    ?
I also received the dual switch today. When I included it in my ISY 5.0.10 3 nodes came up,  ZW  133-1, ZW 133-001  and ZW 133-002 .
133-1 and 133-001 control the same plug and 133-002 the other. It works fine so far, but why do I have 2 nodes controlling the same plug ?................."
For multichannel devices, some devices support the same feature in the root device as well as the channels.  We are adding code to detect this, so you should no longer have this duplication for most devices.
Can you set the value to 0 and query it, then set it to 1 and query it, then set it to 2 and query it and then post all the output ... I want to see if there are any anomalies when setting it to 2
Output should contain lines something like this:
// Set config to 0
Sun 11/05/2017 18:52:22 : [ZWAVE-TX ZW011_1] [70/04] CC=0x70 cmd=0x04 [010100] ACK,AUTO,EXPLORE To=0x0B
Sun 11/05/2017 18:52:33 : [ZWAVE-TX ZW011_1] [70/05] CC=0x70 cmd=0x05 [01] ACK,AUTO,EXPLORE To=0x0B
Sun 11/05/2017 18:52:33 : [ZWAVE-RX ZW011_1] [70/06] CC=0x70 cmd=0x06 [010100] ACK,AUTO,EXPLORE From=0x0B
// Set config to 1
Sun 11/05/2017 18:52:22 : [ZWAVE-TX ZW011_1] [70/04] CC=0x70 cmd=0x04 [010101] ACK,AUTO,EXPLORE To=0x0B
Sun 11/05/2017 18:52:33 : [ZWAVE-RX ZW011_1] [70/06] CC=0x70 cmd=0x06 [010101] ACK,AUTO,EXPLORE From=0x0B
// Set config to 2
Sun 11/05/2017 18:52:22 : [ZWAVE-TX ZW011_1] [70/04] CC=0x70 cmd=0x04 [010102] ACK,AUTO,EXPLORE To=0x0B
Sun 11/05/2017 18:52:33 : [ZWAVE-RX ZW011_1] [70/06] CC=0x70 cmd=0x06 [0101??] ACK,AUTO,EXPLORE From=0x0B
Thu 11/09/2017 11:06:41 : [ZWAVE-TX ZW015_1] [70/04] CC=0x70 cmd=0x04 [010100] ACK,AUTO,EXPLORE To=0x0F
Thu 11/09/2017 11:06:41 : [ZWAVE-RX        ] [0104011301E8]                          [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:42 : [ZWAVE-RX        ] [01050013D6003F]                        [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:42 : [uZW-CMD 29      ] Set Config : ZW015_1 1/1/0
Thu 11/09/2017 11:06:42 : [ZWAVE-TX ZW015_1] [70/05] CC=0x70 cmd=0x05 [01] ACK,AUTO,EXPLORE To=0x0F
Thu 11/09/2017 11:06:42 : [ZWAVE-RX        ] [0104011301E8]                          [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:42 : [ZWAVE-RX        ] [01050013D7003E]                        [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:42 : [ZWAVE-RX ZW015_1] [70/06] CC=0x70 cmd=0x06 [010100] ACK,AUTO,EXPLORE From=0x0F
Thu 11/09/2017 11:06:42 : [uZW-CMD 28      ] Query Config : ZW015_1 param 1
Thu 11/09/2017 11:06:44 : [ZWAVE-TX ZW015_1] [70/05] CC=0x70 cmd=0x05 [01] ACK,AUTO,EXPLORE To=0x0F
Thu 11/09/2017 11:06:44 : [ZWAVE-RX        ] [0104011301E8]                          [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:44 : [ZWAVE-RX        ] [01050013D80031]                        [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:44 : [ZWAVE-RX ZW015_1] [70/06] CC=0x70 cmd=0x06 [010100] ACK,AUTO,EXPLORE From=0x0F
Thu 11/09/2017 11:06:44 : [uZW-CMD 28      ] Query Config : ZW015_1 param 1
Thu 11/09/2017 11:06:50 : [ZWAVE-TX ZW015_1] [70/04] CC=0x70 cmd=0x04 [010101] ACK,AUTO,EXPLORE To=0x0F
Thu 11/09/2017 11:06:50 : [ZWAVE-RX        ] [0104011301E8]                          [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:50 : [ZWAVE-RX        ] [01050013D90030]                        [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:50 : [uZW-CMD 29      ] Set Config : ZW015_1 1/1/1
Thu 11/09/2017 11:06:50 : [ZWAVE-TX ZW015_1] [70/05] CC=0x70 cmd=0x05 [01] ACK,AUTO,EXPLORE To=0x0F
Thu 11/09/2017 11:06:50 : [ZWAVE-RX        ] [01050013DA0033]                        [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:50 : [ZWAVE-RX ZW015_1] [70/06] CC=0x70 cmd=0x06 [010101] ACK,AUTO,EXPLORE From=0x0F
Thu 11/09/2017 11:06:50 : [uZW-CMD 28      ] Query Config : ZW015_1 param 1
Thu 11/09/2017 11:06:51 : [ZWAVE-TX ZW015_1] [70/05] CC=0x70 cmd=0x05 [01] ACK,AUTO,EXPLORE To=0x0F
Thu 11/09/2017 11:06:51 : [ZWAVE-RX        ] [0104011301E8]                          [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:51 : [ZWAVE-RX        ] [01050013DB0032]                        [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:51 : [ZWAVE-RX ZW015_1] [70/06] CC=0x70 cmd=0x06 [010101] ACK,AUTO,EXPLORE From=0x0F
Thu 11/09/2017 11:06:51 : [uZW-CMD 28      ] Query Config : ZW015_1 param 1
Thu 11/09/2017 11:06:56 : [ZWAVE-TX ZW015_1] [70/04] CC=0x70 cmd=0x04 [010102] ACK,AUTO,EXPLORE To=0x0F
Thu 11/09/2017 11:06:56 : [ZWAVE-RX        ] [0104011301E8]                          [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:56 : [ZWAVE-RX        ] [01050013DC0035]                        [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:56 : [uZW-CMD 29      ] Set Config : ZW015_1 1/1/2
Thu 11/09/2017 11:06:56 : [ZWAVE-TX ZW015_1] [70/05] CC=0x70 cmd=0x05 [01] ACK,AUTO,EXPLORE To=0x0F
Thu 11/09/2017 11:06:56 : [ZWAVE-RX        ] [01050013DD0034]                        [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:56 : [ZWAVE-RX ZW015_1] [70/06] CC=0x70 cmd=0x06 [010101] ACK,AUTO,EXPLORE From=0x0F
Thu 11/09/2017 11:06:56 : [uZW-CMD 28      ] Query Config : ZW015_1 param 1
Thu 11/09/2017 11:06:58 : [ZWAVE-TX ZW015_1] [70/05] CC=0x70 cmd=0x05 [01] ACK,AUTO,EXPLORE To=0x0F
Thu 11/09/2017 11:06:58 : [ZWAVE-RX        ] [0104011301E8]                          [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:58 : [ZWAVE-RX        ] [01050013DE0037]                        [00/00] CC=0x00 cmd=0x00 [] ACK,AUTO,EXPLORE
Thu 11/09/2017 11:06:58 : [ZWAVE-RX ZW015_1] [70/06] CC=0x70 cmd=0x06 [010101] ACK,AUTO,EXPLORE From=0x0F
Thu 11/09/2017 11:06:58 : [uZW-CMD 28      ] Query Config : ZW015_1 param 1
I even tried using REST commands and could not get it to accept 2.
I'll wait till you get the modules in hand.
Best regards,
Gary Funk
  • 1 month later...
Hi Everyone,
There was some confusion with the parameters for the Inovelli Dimmer.  Here are the actual parameter options (Thanks to Eric from Inovelli for the update)
Parameter 1 (1 byte) - If parameter 2 is set to 0
0 - Turn indicator light ON when switch is OFF
1 - Turn indicator light ON when switch is ON
Parameter 2 (1 byte)
0 - Enable indicator light
1 - Disable indicator light
Thank you, Eric and Chris and Eric M.
I'd say it is a documentation issue that caused that confusion.
I see from post #5 that Eric also updated the solution.
Do you have any insight to the 2-Channel On-Off Power Switch Module? Or should ISY users just ignore the main node?
Best regards,
Gary Funk
Edited by Gary Funk
Best regards,
Gary Funk
Hi Gary,
The 2-Channel does not appear to support the Configuration command class so I doubt there is a way to modify the LED behavior.
EDIT:
Oops, now I see what you asking ... You can ignore the main node, but you can also use it as a Z-Wave scene responder for controllers that do not support multichannel association.
Hi Gary,
EDIT:
I started a new topic here: https://forum.universal-devices.com/topic/23129-inovelli-z-wave-nzw37-plig-in-module-2-channel-switch/
  • 1 year later...
On 10/29/2017 at 11:34 PM, Eric_Inovelli said:
__________________________________________________________________________
Update 2017/12/13
Good evening,
This is Eric from Inovelli -- just wanted to help out with the parameter issue. We're terribly sorry they weren't listed in the instructions (we fixed it for the next version) but below is the parameter information for future reference:
Parameter 1 - size 1 byte
00 is Light Off / LED On
01 is Light On / LED On
02 is Disable LED
Hope this helps and thanks so much for your support!
Eric
Founder | Inovelli
Eric,
It took me while but I just succeeded to invert the led so that led is ON when switch is OFF.
This is what I did :
Parameters 1,2 and 3 all set to 0 (zero)
