Google Home Shortcuts
Hello,
I have ISY portal, everything is setup and working properly. Example: I can control all my lighting using "Ok Google, turn on all lights". and it turns on all the light in my house at once.
What I want to do is use a Shortcut in the Google Home Assistant to say "Ok Google, Bedtime" and have it turn off all my lights in the house.
The shortcuts in google home tell you "When I say... Bedtime" "Google assistant should do... ask isy(?) to turn off all lights"
Any help as to how to properly word the shortcut to work?
James.
Let me check on how mine does it. I think I say turn off all lights and it does it.
Hello,
James.
I played  with this a a few weeks ago and noticed that Google 'reserved'  some shortcuts and for example 'Good Night" does not work as a shortcut. I even tried 'Buenas Noches'  and then GH translates this in English :-)
Odd, I have a shortcut ‘good night’ that triggers just fine as a shortcut. It’s been there for a while now, used pretty much every evening to turn everything off...
