Google Home Shortcuts
Hello,
I have ISY portal, everything is setup and working properly. Example: I can control all my lighting using "Ok Google, turn on all lights". and it turns on all the light in my house at once.
What I want to do is use a Shortcut in the Google Home Assistant to say "Ok Google, Bedtime" and have it turn off all my lights in the house.
The shortcuts in google home tell you "When I say... Bedtime" "Google assistant should do... ask isy(?) to turn off all lights"
Any help as to how to properly word the shortcut to work?
James.
Hello,
James.
I played  with this a a few weeks ago and noticed that Google 'reserved'  some shortcuts and for example 'Good Night" does not work as a shortcut. I even tried 'Buenas Noches'  and then GH translates this in English :-)
Odd, I have a shortcut ‘good night’ that triggers just fine as a shortcut. It’s been there for a while now, used pretty much every evening to turn everything off...
