apostolakisl Posted December 12, 2017 Posted December 12, 2017 This is a 2477D. The on level is set to 72% and it used to work. Now, when manually controlled, it goes to 100%. Also, the admin console for a split second shows 72%, then it reverts to "off". A query corrects that to 100%. If I use the admin console to turn it on, it goes to 72% and shows 72%. Of course I did a factory reset and restore device. The switch used to go correctly go to 72% when manually controlled. I noticed it going to 100% maybea few weeks ago but didn't look into it until today. Here is the ISY comm log. I am starting in the off state, clicking the on paddle, then a few seconds later clicking the off paddle. Tue 12/12/2017 06:55:04 AM : [iNST-SRX ] 02 50 43.D2.76 00.00.01 CB 11 00 LTONRR (00) Tue 12/12/2017 06:55:04 AM : [std-Group ] 43.D2.76-->Group=1, Max Hops=3, Hops Left=2 Tue 12/12/2017 06:55:04 AM : [D2D EVENT ] Event [43 D2 76 1] [DON] [0] uom=0 prec=-1 Tue 12/12/2017 06:55:04 AM : [ 43 D2 76 1] DON 0 Tue 12/12/2017 06:55:04 AM : [D2D EVENT ] Event [43 D2 76 1] [sT] [184] uom=100 prec=0 Tue 12/12/2017 06:55:04 AM : [ 43 D2 76 1] ST 184 (uom=100 prec=0) Tue 12/12/2017 06:55:05 AM : [iNST-SRX ] 02 50 43.D2.76 00.01.01 CB 11 01 LTONRR (01) Tue 12/12/2017 06:55:05 AM : [std-Group ] 43.D2.76-->Group=1, Max Hops=3, Hops Left=2 Tue 12/12/2017 06:55:05 AM : [D2D EVENT ] Event [43 D2 76 1] [DON] [1] uom=0 prec=-1 Tue 12/12/2017 06:55:05 AM : [ 43 D2 76 1] DON 1 ----->>>>>Tue 12/12/2017 06:55:05 AM : [D2D EVENT ] Event [43 D2 76 1] [sT] [1] uom=100 prec=0<<<<<---- ? is this the problem? Tue 12/12/2017 06:55:05 AM : [ 43 D2 76 1] ST 1 (uom=100 prec=0) Tue 12/12/2017 06:55:05 AM : [iNST-SRX ] 02 50 43.D2.76 11.00.01 CB 06 00 (00) Tue 12/12/2017 06:55:05 AM : [std-Group ] 43.D2.76-->11.00.01, Max Hops=3, Hops Left=2 Tue 12/12/2017 06:55:05 AM : [iNST-INFO ] Previous message ignored. Tue 12/12/2017 06:55:08 AM : [iNST-SRX ] 02 50 43.D2.76 00.00.01 CB 13 00 LTOFFRR(00) Tue 12/12/2017 06:55:08 AM : [std-Group ] 43.D2.76-->Group=1, Max Hops=3, Hops Left=2 Tue 12/12/2017 06:55:08 AM : [D2D EVENT ] Event [43 D2 76 1] [DOF] [0] uom=0 prec=-1 Tue 12/12/2017 06:55:08 AM : [ 43 D2 76 1] DOF 0 Tue 12/12/2017 06:55:08 AM : [D2D EVENT ] Event [43 D2 76 1] [sT] [0] uom=100 prec=0 Tue 12/12/2017 06:55:08 AM : [ 43 D2 76 1] ST 0 (uom=100 prec=0) Tue 12/12/2017 06:55:08 AM : [iNST-SRX ] 02 50 43.D2.76 00.01.01 CB 13 01 LTOFFRR(01) Tue 12/12/2017 06:55:08 AM : [std-Group ] 43.D2.76-->Group=1, Max Hops=3, Hops Left=2 Tue 12/12/2017 06:55:08 AM : [D2D EVENT ] Event [43 D2 76 1] [DOF] [1] uom=0 prec=-1 Tue 12/12/2017 06:55:08 AM : [ 43 D2 76 1] DOF 1 Tue 12/12/2017 06:55:08 AM : [iNST-SRX ] 02 50 43.D2.76 13.00.01 CB 06 00 (00) Tue 12/12/2017 06:55:08 AM : [std-Group ] 43.D2.76-->13.00.01, Max Hops=3, Hops Left=2 Tue 12/12/2017 06:55:08 AM : [iNST-INFO ] Previous message ignored. EDIT: I changed the ramp rate, and now the switch is behaving correctly (local on paddle press - > 72%). However, the admin console still flashes "72%" for a split second and then goes back to "off".
stusviews Posted December 12, 2017 Posted December 12, 2017 If you originally selected a 9 min ramp rate, then that may be the problem. That ramp rate is to accommodate older devices and does not exist for current devices.
apostolakisl Posted December 12, 2017 Author Posted December 12, 2017 If you originally selected a 9 min ramp rate, then that may be the problem. That ramp rate is to accommodate older devices and does not exist for current devices. No. 1/2 second. I changed to 2 seconds, then it worked. Changed back to 1/2 second and that part at least still works (turning on to 72% rather than 100%).. However, it still appears to be sending two status updates, the second one with a status level of "1", meaning 1/256 or effectively 0% The first status update it sends is 184. Or 184/256=72% . . . correct. But the second one comes less than a second later and is wrong. I don't know why it is sending two at all, let alone why the second is wrong.
apostolakisl Posted December 14, 2017 Author Posted December 14, 2017 I fixed it. I had to completely delete it from ISY, factory reset it, then re-add it and re-build the scene and switch attributes. I don't know how that fixed this problem, but it did.
stusviews Posted December 14, 2017 Posted December 14, 2017 A factory reset is often all that's needed when you come across an errant device. BTW, you usually don't need to delete the device. Try a factory reset, then use the ISY to rebuild the links (scenes) and programs, right click, then Restore Device often followed by Write Updates to Device.
apostolakisl Posted December 14, 2017 Author Posted December 14, 2017 A factory reset is often all that's needed when you come across an errant device. BTW, you usually don't need to delete the device. Try a factory reset, then use the ISY to rebuild the links (scenes) and programs, right click, then Restore Device often followed by Write Updates to Device. Please see post 1.
