Program issue
I have two trane z-wave thermostats that are connected to the isy944izw and working fine.
I wrote a program to check the temperature and send me an email if the temperature drops below 55 degrees.
When we are away for weeks at a time I keep the temperature at 60 degrees.
My problem is that I get emails at various times telling me that the temperature is below 55 degrees. When I check it the temp is holding stead at 60 degrees.
IF
   Status  'HVAC 1st Floor Thermostat' < 55 F
THEN
   Send Notification to 'Comcast1' context 'Heat Alarm - First Floor'
Comcast1 is the email I set up for the isy.
I must be doing something wrong to be getting false readings (alarms). Do I have to tell it when to check?
Any help would be appreciated!
Sometimes devices can quickly report an intermediary value when switching from calling / not calling (fan, heat, cool, humidity). The way to test this out is to add a 30 second to 1 minute wait as the first statement of the "then". If it changes briefly this will ignore the fast changes.
Paul
Edited by paulbates
