Controlling on/off switch with keypad
Pretty basic question: is there a way to remotely control a light switch from a key on an 8-button keypad besides creating a scene and making the key the controller? Is it possible to control the switch directly without a scene?
Use a program
If button pushed
Then turn on light
Read about programming in the Wiki and I'm sure you"ll be doing much more...
http://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Add_to_Program
Typically you will use " If Control [button ID] is switched On" to track a button press programmatically.
Why are you opposed to using a scene?  There will be a slight delay doing it with a program.
